problem starting when hot
Old Jul 16, 2002 | 12:24 PM
mercury's Avatar
New User
Default problem starting when hot
The car is a '92 Civic Si hatchback, completely stock.
Sometimes when the engine is still warm and I go to start the car, it fires up, but immediately stalls. It only does this intermittently when the engine is warm, not when cold. Another clue I have is when I turn the key to the "ON" position, sometimes I won't hear the fuel pump priming, and those are the times when the car will stall after I crank it.
Is this a relay problem, fuel pump problem, or both? Which relays are involved getting the fuel pump going?
Old Jul 16, 2002 | 02:43 PM
Chiovnidca's Avatar
Default Re: problem starting when hot (mercury)
Did you check your main relay?
Old Jul 16, 2002 | 05:53 PM
BreakStuff's Avatar
New User
Main relay controls signal to the fuel injection circuit and fuel pump itself, the symptoms of a failing main relay are exactly what you have described..
Old Jul 16, 2002 | 07:15 PM
tinkerbell's Avatar
Default Re: problem starting when hot (BreakStuff)
plus i have seen it documented that hte main relay can get a bit cantankerous when warm...
some reports suggest that your can open it up and check for loose solder joints...
or you can replace.
to know for sure, locate the main relay and have someone turn the key to on nad it should;
click - 2 second pause - click
HTH,
t..
jerome^galon
Jan 4, 2012 07:03 PM
vee-spec
Mar 23, 2010 07:37 PM
PatrickFrantz
Aug 21, 2008 05:53 AM
nonbox
Jan 30, 2006 01:00 PM
RenoRacing
Sep 8, 2002 09:41 PM
