spark plugs ok? car shut off in boost
Old Jun 1, 2008 | 05:53 PM
drift2004's Avatar
Default spark plugs ok? car shut off in boost
92 hatch ls/vtec s200, 1000cc, 91 octane, gt3076r 255 walbro pump
ok so when i am driving and i hit boost and it feels like i get a fuel cut it sometimes does it and sometimes it does not and i get off the gas and give it more gas and it starts to go again could it be my spark plugs i need new ones?
Old Jun 1, 2008 | 06:41 PM
1995Civic's Avatar
Are you running a colder plug than when you were stock? When was the last time you changed them?
Old Jun 1, 2008 | 06:47 PM
jDMJeRk's Avatar
plugs look good in my opinion, what do you have them gapped to?
Old Jun 1, 2008 | 06:52 PM
1995Civic's Avatar
Default Re: (jDMJeRk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk &raquo;</TD></TR><TR><TD CLASS="quote">plugs look good in my opinion, what do you have them gapped to?</TD></TR></TABLE>
Lol..I failed to look at the pics
Old Jun 1, 2008 | 07:42 PM
DrivenMC's Avatar
Banned
Default Re: spark plugs ok? car shut off in boost (drift2004)
How much boost you running ? Sounds like the spark is blowing out. What ignition setup do you have?
Old Jun 1, 2008 | 07:43 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
plugs look good i see no signs of detonation on the inside of the plug. especially if it shut off during boost that would be the best read anyway. i say your having a fuel cut issue somewhere. or going into limp mode or a blown plug maybe......gap?
Old Jun 2, 2008 | 05:17 AM
DrivenMC's Avatar
Banned
Default Re: (HybridcivicLS-T)
If the engine was hitting some type of fuel cut then the plugs would show detonation from leaning out. What type of tuning system are you running? Also, Do you have any A/R readings?
Old Jun 2, 2008 | 07:06 AM
drift2004's Avatar
Default Re: (DrivenMC)
19 pounds but even at 15 it would do it, i have stock ignition, with msd spark plug wires, this all started after i had it re tuned i will try some new plugs see how it works
Old Jun 2, 2008 | 07:34 AM
blaze the chemi's Avatar
Default Re: (drift2004)
That gap seems a little too tight. What is the gap exactly? Also your ground electrode shouldn't be that white. The blackness on the ground should be closer to the midpoint. Your blackness is close to the threads. Maybe it's the pictures that make it seem that way.
Old Jun 2, 2008 | 07:35 AM
98vtec's Avatar
moderator emeritus
i'd prolly retard the timing a little bit. Looks to me that the ground strap is getting burnt almost to the base of the plug.
what plug gap are you running?
Old Jun 2, 2008 | 01:36 PM
blackeg's Avatar
Default Re: (98vtec)
get that gap down to around .020". also the last plug in the pic looks a little richer than the others, but i definately dont see any detonation signs. id hope you are at least running a 7 or 8 heat range on the plugs
Old Jun 2, 2008 | 02:00 PM
KooK's Avatar
Mustang Sally
Default Re: (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">get that gap down to around .020". also the last plug in the pic looks a little richer than the others, but i definately dont see any detonation signs. id hope you are at least running a 7 or 8 heat range on the plugs</TD></TR></TABLE>
Hooollly what? .020? The smallest I have ever had to go on anything is .025
Phatch99
Sep 8, 2005 12:39 PM
b18c198
Jul 13, 2005 08:06 PM
u_tal
Nov 10, 2004 03:01 PM
patdemps
May 25, 2004 06:08 AM
TuRbO_CrX_7o2
Feb 1, 2004 05:28 AM
