strange stalling issue - need help
Old Jun 1, 2008 | 10:59 AM
sicivic's Avatar
Default strange stalling issue - need help
So the car is a 89 Civic Si running a 91 Si ECU. The car has the Fields Vtec controller only hooked to activate vtec on a D16Z6 head, fuel isn't wired up to the MAP sensor. Every now and then, the car will stall while coming to a stop or idling. I will go to restart it and it will fire up and then sputter and stall again. Next, I will try to restart it again and it will just turn over. I will try and try but it won't start. Just turning over. Then after maybe a minute of trying numerous times to start, it will fire up with me giving it some gas and rev up a few thousand rpms and then bogg down and stall again. Then I will try some more to start it, but the motor just turns over with no hint of starting. Eventually it will start up and be fine. Kinda of a strange issue. ECU isn't flashing any codes either.
Could it be a fuel pump since there aren't any codes? I'm not sure where to start here.
Any help would be appreciated.
Old Jun 2, 2008 | 09:23 AM
sicivic's Avatar
Default Re: strange stalling issue - need help (sicivic)
Any ideas?
Old Jun 10, 2008 | 09:52 AM
sicivic's Avatar
anyone have any ideas?
Old Jun 10, 2008 | 11:13 AM
scottmog's Avatar
I had this issue with a 89 dx crx. Ended up being the cellinoid, something like an mid 90's integra one was in there. Strange problem I hated it lol. Find an entire starter in a pickurpart or just a cellinoid and see if that's ur problem
Old Jun 11, 2008 | 08:26 PM
sicivic's Avatar
Default Re: strange stalling issue - need help (Mog)
No, its definitely not starter related.
Integra4lyfe069
15
Mar 10, 2009 02:51 PM
dubzz24
Mar 2, 2007 09:14 AM
Crimson_Tide
Oct 2, 2005 08:26 PM
DeDonDeRosa
Dec 1, 2003 04:31 PM
