emergency brake emergency
Old Jun 1, 2008 | 05:02 AM
beastman@'s Avatar
Default emergency brake emergency
If I'm parked on a hill and I pull the e-brake all the way up, my car will roll. It feels like the brakes just aren't grabbing, is there a way to adjust the tension?
Old Jun 1, 2008 | 05:45 AM
Tegraracer90's Avatar
Default Re: emergency brake emergency (beastman@)
well there is a few things that need to be checked before adjusting the cable....1st off..check the rear rotors to make sure there is not rust...this will tell you in fact that the rear calipers arent siezed...if there is no rust...how much pad do you have left...if there is plenty of pad...then inside the car..the rear section of your center consol needs to come out
Remove the consol by using a flat scrw driver and pull off the little tab cover under the emergancy brake handle..under that you will find 2 screws..remove them...then on the back of the consol you will find more smaller screws...remove them..once its lose...remove it...
then once its off you will see two cables coming up from the rear...each should have a nut at the end with a metal bracket attached to your e-brake handle..with the e-brake released...tighten each nut the same amount of turns...if you dont tighten them the same amount of turns...one side will brake harder then the other...tighten it until it feels a bit harder to pull the e-brake...test it out..if it feels like it holds the car and the brakes dont drag while u drive...then reassemble
Old Jun 1, 2008 | 07:50 AM
Sic_DA_Nine's Avatar
yeah..happens to me to.
my pads are still full with life, and my cable was adjusted..but it does the same ****..so i kinda gave up. i just park really close to a curb and keep the car in gear on hills
Old Jun 2, 2008 | 06:38 AM
beastman@'s Avatar
Default Re: (Sic_DA_Nine)
Thanks guys, I really just think it needs to be tightened because it comes up way too easy.
Old Jul 13, 2008 | 07:39 PM
beastman@'s Avatar
Default Re: (beastman@)
I tightened the cables as much as I could.
Today I put the back end up on jackstands. One side is rock solid tight while the other spins almost freely.
Anyone know why it's like this? Or how to fix it?
Old Jul 14, 2008 | 09:10 AM
hondroid015183's Avatar
I had the same problem in my 97 GSR. I had put on a re-man caliper and it was re-built improperly, I went through three (third was from a different parts store) before I got by e-brake to work properly. Or, if it is adjusted all the way, your cables could be stretched.
Old Jul 15, 2008 | 05:45 AM
beastman@'s Avatar
Default Re: (hondroid015183)
Anyone else?
Old Jul 15, 2008 | 09:32 AM
cetcivic's Avatar
no one wants to hear the truth
sounds like a seized caliper..had a similar issue recently resolved w/ new caliper
cheapo23
Jun 2, 2010 09:28 PM
PreludePhill
May 5, 2006 07:22 AM
Teggys1ClnDA
Jan 6, 2005 12:49 PM
Type Goch
Sep 11, 2002 12:41 PM
Type-R 940
Mar 20, 2002 10:51 AM
