MY02 WRX 420 Inj. - H22 FI
Like the topic reads, wondering if my stock 420cc stock WRX injectors could be used with an H series for a boosted setup? Will be tuning using S300, but more concerned with physical fitment.
TIA
Jerod
TIA
Jerod
STi uses sidefeed, WRX uses topfeed (and saturated). The 420's are only good for ~300whp with a high pressure pump and a base pressure of over 55psi. Seeing how moderate B16 setups can max those out (as in t3 under 10psi), that is a poor choice for injectors IMO. With today's EMS's for Hondas, people are running 1000cc injectors w/o any idle/drivability issues. I'd say sell them on ebay for around $100, then spend another $150 to get precision 750cc or larger peak & hold injectors and resistor box.
BTW I forgot about this page, if you have the right injectors, they could become 740cc injectors: http://www.teamscss.com/Subaru...d.htm The only problem is that people rate the incresed flow from 560cc to 740cc, so best to spend another $60 to get them cleaned & flowtested.
Modified by HiProfile at 8:58 AM 6/1/2008
