Nitrous question.
Old May 31, 2008 | 06:45 PM
4dooritr's Avatar
Default Nitrous question.
Has anyone had bad experince with a dry 35-50 shot on a stock internal ITR?
Since I'm going back to a quieter exhaust and losing a few hp.. want a small SAFE shot just for when we need the extra hp
think 35-50shot, retard the timing n tune would be safe enough for a daily driver?
Old Jun 1, 2008 | 08:51 PM
dx2sicrx's Avatar
Default Re: Nitrous question. (4dooritr)
Im not sure on the itr but i sprayed about 7-10 bottles worth of nitrous through my ls within a 3 month period, and my motor stood up to the challenge. this motor had about 150,xxx miles and never had anything done to it. I didnt blow it up, it didnt start knocking, or even smoking. I ran the zex kit, 75 hp shot, and even had the timing slightly advanced. I ran regular ngk's but did put 93 octane gas and usually and additive when I planned on spraying. when i first put the bottle on I ran the timing reatarded like it says to do but was slow so I put it normal and adavanced it with the dizzy. I am now going to put it on my GSR, well b16 block and GSR head, to see what happened. I loved it when I sprayed, it was fun as hell. The first kit i had went on a trade for a turbo kit, and within a couple of days of having boost I ordered another nitrous kit. I really missed the nitrous that much.
Old Jun 1, 2008 | 09:33 PM
Jimmy's Avatar
Global Moderator
Yes if you take the proper procedures..
Spark plugs, timing, tune.. yes it should be fine..
I wouldn't spray all the time though.. maybe track use only.. Depending how fast you want to wear the engine
Old Jun 2, 2008 | 03:52 AM
rd91sib18c5r's Avatar
I have a zex dry kit on my b18c5 running a 75shot and it runs good with no
problems after 4 bottles, just retard the timing 2deg for every 50horse and
run good gas. Have fun
Old Jun 2, 2008 | 08:46 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dooritr &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone had bad experince with a dry 35-50 shot on a stock internal ITR?
i've run over 100 hp shot on stock internal LS / GSR / B16/ and H22 with no problems.. also run 75+ on single cams also with no problems.. make sure to get it tuned before running any bottle!!!
Old Jun 3, 2008 | 01:44 PM
EJ8chu's Avatar
Default Re: Nitrous question. (h22crxpwr)
100 Shot dry on a stock internal jdm gsr. Like said before, spark plugs, timing, and a tune you will be more than fine
JDMIntegraB16
Nov 29, 2005 07:25 PM
keepitjdm
Dec 9, 2004 06:44 AM
99skunkedSi
Mar 3, 2004 08:05 AM
91SIR
Mar 31, 2003 09:58 AM
scrubachu
Jan 9, 2002 06:11 AM
