injecters wont fire someone please help!!!
Old May 31, 2008 | 03:46 PM
CTR LOVER LU's Avatar
Default injecters wont fire someone please help!!!
i have a 91 dx hatch i did a mpfi conversion followed all the steps given 2 me. i have a obd2 motor, obdo dist. , obd1 ls ecu, obd2 injecters,. whe injecters are not firing i checked the wiring over and over again i also used a pm6 pinout sheet to make sure can any 1 heip me out ?
Old May 31, 2008 | 03:49 PM
revikan's Avatar
Default Re: injecters wont fire someone please help!!! (CTR LOVER LU)
Did u wire your injectors to the resistor box? if so, you dont need the box with obd2 injectors
Old May 31, 2008 | 03:58 PM
Default Re: injecters wont fire someone please help!!! (revikan)
yea i did so if i dont need it wat should i do ?
Old May 31, 2008 | 04:43 PM
TRUcrxEr's Avatar
because you have the injectors wired into the resistor box, they are getting limited voltage. the injectors you have require a full 12 volts and the resistor box is not allowing for that. take the 5 pin connector going into the resistor box, de-pin the connector and solder the wires together.
what this will do is bypass the resistor box and a full 12 volts to the injectors which is what you need.
*assuming all of the wiring is correct
Old May 31, 2008 | 04:57 PM
Default Re: injecters wont fire someone please help!!! (TRUcrxEr)
ok thanks a a bunch im really thankful
Old Jun 1, 2008 | 12:02 PM
i wired them all direct and they still wont fire
gunfighter91
Jun 29, 2018 03:12 AM
Bigkev616
Oct 17, 2009 06:18 AM
91EF919
Oct 9, 2008 06:34 PM
immorality
May 24, 2008 03:46 PM
nitewolf
Mar 25, 2008 07:04 PM
