just wondering..how do you guys install your front lips??do you guys install it different then me??
i install my front lip by just screwing two screws on both sides and the supporting bracet on the middle....if you have any better or different way then please let me know please..
Stock hardware on the front (7+ clips and bolts I think, plus a screw in each end).
Custom brackets for the rear lip (OE were broken off by another owner) plus 7+ bolts holding it on along with a screw in each end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">Stock hardware on the front (7+ clips and bolts I think, plus a screw in each end).
Custom brackets for the rear lip (OE were broken off by another owner) plus 7+ bolts holding it on along with a screw in each end.</TD></TR></TABLE>
NOFX ur ma dogg when it comes to info, but you tryna drive these people broke my brotha..!!
stock oem hardware at honda is like $60 bucks lol, same exact hardware at ace hardware/true value is about $6 bucks... It cost just as much for the hardware at honda as it does for the lip itself almost haha... Someone was definitely smoking hashish/crack/heroin mixture when they priced those clips/screws lol...
Sorry, I have stock brackets (that come on the lip) on the front lip. The bolts are not stock hardware, but the same basic **** you'd buy at Honda, only stronger, less likely to rust and less expensive.
This is more to say HOW everything is bolted on though, not who sold it to whoever.
And no, the hardware's not anything close to the cost of the lip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NOFX »</TD></TR><TR><TD CLASS="quote">Sorry, I have stock brackets (that come on the lip) on the front lip. The bolts are not stock hardware, but the same basic **** you'd buy at Honda, only stronger, less likely to rust and less expensive.
And no, the hardware's not anything close to the cost of the lip.</TD></TR></TABLE>
It is if you get the lip off ebay
And what kinda bolts u using, galvanized..??
well my oem lip is broken so, i hold it up by screwing it directly on..
but before, i use the 2 screw on each side 2 bolt on the bottom sides and a bolt and a plate in the middle (to prevent it from being stolen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1CaMw0nDeR »</TD></TR><TR><TD CLASS="quote">It is if you get the lip off ebay
And what kinda bolts u using, galvanized..??</TD></TR></TABLE>
I don't buy lips off eBay unless I know what it is (OEM, not replica or some off brand).
The bolts are stainless steel and the spring nuts are powerd coated black.
The bolts are stainless steel and the spring nuts are powerd coated black.</TD></TR></TABLE>
I'd hope u wouldnt buy any other lip other than OEM anyways lol...
Can any body post a pic of hoe to screw on an ek coupe front and back lip?i dont get it by ( 7 clips)??
YoungMoneySi
Mar 31, 2008 11:38 AM
