Making a mold out of clay... mold release?
Old May 31, 2008 | 05:42 AM
JDubya's Avatar
Default Making a mold out of clay... mold release?
I need to make a really simple, small, one-time-use positive mold. I first tried the fabric stretching technique, it worked OK but I need more control in the final shape than I had originally thought. My next idea was to just use some Klean Klay to shape the mold. Would I then need any type of mold release? I know you could always peel off any clay that stuck to the finished piece but if I can make it easier, why not. I don't have any PVA though. It'll be a fairly light lay-up so hopefully heat wont cause the clay to distort. I have polyester and epoxy resins and will probably go with the epoxy. I haven't decided if i want to use FG or CF. Any tips are appreciated.
Old May 31, 2008 | 06:03 AM
PeakBoost's Avatar
B*A*N*N*E*D
Default Re: Making a mold out of clay... mold release? (JDubya)
have you thought about using any high density foams to create your positive shape?
after your object is made, plaster of paris/sand/paint/PVA. I know you said you don't have any release agents, why not order some?
I personally think the clay will melt or distort from the heat of the resin.
Old May 31, 2008 | 06:07 AM
JDubya's Avatar
Default Re: Making a mold out of clay... mold release? (PeakBoost)
I have thought about foams but wasn't sure which to use.
I'm really going for quick and easy with this one, not perfection as the final part isn't critical. I'm making a shroud that'll sit behind a bezel in a HID retrofit.
I do have release agents but they're the kind you buff on and off, not something that would work with clay, albeit rather hard clay.
Old Jun 1, 2008 | 06:59 PM
skellator_thoj's Avatar
why won't take the clay and get a rough shape and take any ester based resin/bondo and pour it over the clay and then reshape the bondo to your specs
Old Jun 3, 2008 | 05:50 PM
thumper64's Avatar
I've made some sand molds before, and we used baby powder as a release agent.
Old Jun 3, 2008 | 07:00 PM
jweller's Avatar
Default Re: Making a mold out of clay... mold release? (thumper64)
I worked with a guy who swore by yellow Joy dish soap cut 1:1 with alcohol and just painted it on. alcohol flashed off and left noithing but soap.
Old Jun 3, 2008 | 07:50 PM
Mr.E.G.'s Avatar
Default Re: Making a mold out of clay... mold release? (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">I worked with a guy who swore by yellow Joy dish soap cut 1:1 with alcohol and just painted it on. alcohol flashed off and left noithing but soap.</TD></TR></TABLE>
holy ****! i just read the cuddle bitch link. ingenious
Old Jun 4, 2008 | 09:31 AM
goforbroke's Avatar
MEAT PATTY
Default Re: Making a mold out of clay... mold release? (Mr.E.G.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.E.G. &raquo;</TD></TR><TR><TD CLASS="quote">holy ****! i just read the cuddle bitch link. ingenious </TD></TR></TABLE>
I just read the entire link. Its so true, every man should read that.
Old Jun 4, 2008 | 11:55 AM
GT35R_EF's Avatar
Make mine whatever you want
Default Re: Making a mold out of clay... mold release? (goforbroke)
They do actually make a mold release wax, i worked in a fiberglass shop and that was what they alwayes used, the more coats you put on the better it would release. We used it on a car mold and it worked great. any fiberglass store should carry it or some version of it.
Old Jun 4, 2008 | 12:34 PM
JDubya's Avatar
Default Re: Making a mold out of clay... mold release? (GT35R_EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GT35R_EF &raquo;</TD></TR><TR><TD CLASS="quote">They do actually make a mold release wax, i worked in a fiberglass shop and that was what they alwayes used, the more coats you put on the better it would release. We used it on a car mold and it worked great. any fiberglass store should carry it or some version of it.</TD></TR></TABLE>
yeah i have the wax type but it can't be used on clay (the wax is harder than the clay). I think i'll try the dish soap method.
for reference here is what i'm doing. This was my first version using the stretched cloth (fleece) method. It worked fine but I need more control over the contours because clearance is tight in some spots.
*the black part under the chrome bezel*
Old Jun 6, 2008 | 12:52 AM
.RTErnie's Avatar
be careful which matrix you use as it may not work with the sizing on the fibers.
I use PVA.... works like a charm.
Old Jun 6, 2008 | 08:18 AM
Optiks.'s Avatar
Default Re: Making a mold out of clay... mold release? (.RTErnie)
Alumminum Foil conforms to stuff well then just pops off
1999hondaex
Paint and Body
Oct 12, 2009 01:27 AM
b20turbojason
Paint and Body
May 1, 2009 12:25 PM
VTEC_PRODUCTION
Paint and Body
25
Apr 24, 2009 12:36 PM
Dsnyneer
Mar 15, 2008 07:39 AM
95gainfla
Paint and Body
May 1, 2007 06:06 PM
