Seats
Old May 31, 2008 | 04:04 AM
Fullthrottle297's Avatar
Default Seats
is it possible to put 95 GSR seats in my 97 hatch without modifying any interior panels? i know the front ones should bolt straight up to my stock rails but im concerned about the back seat whether or not it will bolt straight in
Old Jun 1, 2008 | 08:35 PM
Default Re: Seats (Fullthrottle297)
bump
Old Jun 1, 2008 | 09:34 PM
994door's Avatar
I'm pretty sure if you searched you could find something faster. But for a hatch you must use the rear seats from a 2 door integra. some one correct me if i'm wrong please.
Old Jun 3, 2008 | 09:53 AM
ej6hatchie's Avatar
bump bump cause im trying to figure out too. so the gsr seats bolt up in the front rails without any problems?
Old Jun 3, 2008 | 10:28 AM
Kingcobra33's Avatar
I just put 97 integra seats into my 96 hatch. I had to change out the inner rails with the ones from my civic seats for the front. There is a write up on here somewhere. The rear seats DO NOT fit. I was able to use the upper portion of the back seats (the ones that fold down), but I had to strip them both down to just frames. The Integra frames won't fit in the hatch unless you do some fabrication. I just removed all of them little bent wires that holds the cloth to the frame and re-upholstered onto the civic frames. As for the back seat (where your butt goes) good luck, the mounts are all off. The write up that I followed the guy re-upholstered onto the civic frame and then used a sewing machine to add the additional material. He went above and beyond, for that OEM look, but couldn't find exact matching material. Personally nobody climbs in the back, so I just have it sitting in there with the seat belts buckled.
https://honda-tech.com/zerothread?id=1436635 how to for the seats
Modified by Kingcobra33 at 11:36 AM 6/3/2008
Dead CIVIC
Nov 8, 2009 09:51 AM
EKing
Aug 30, 2009 10:43 AM
Jake Pwns Hard
Nov 11, 2008 03:05 PM
Jebus
Feb 9, 2003 05:32 PM
aw1234dude
Jan 21, 2003 02:23 PM
