HELP!!!!
Old May 30, 2008 | 04:44 PM
jordan_civic's Avatar
Default HELP!!!!
Someone please help me. I have posted maybe 3-4 times about this and got maybe 2 replies that didnt help at all.
I have a built b18c turbo. I turn it on and the idle goes up and down eventually dying within a minute and dies if you open the throttle at all.
Please someone has to know whats up here?....
Thanks
Old May 30, 2008 | 04:55 PM
IOSUA's Avatar
Default Re: HELP!!!! (jordan_civic)
check your dizzy cap and rotor. maybe your not getting enough spark. idk.. do you have a check engine light??
Old May 30, 2008 | 04:57 PM
Default Re: HELP!!!! (IOSUA)
No CELs... It was running fine a week ago. I took the cap off and looked at the dizzy and its all good. Almost everything is under 3000 miles old.
Old May 30, 2008 | 05:17 PM
IOSUA's Avatar
check your timming.
Old May 30, 2008 | 05:38 PM
Timing is fine. It has to be electrical or a sensor. Because I havent changed anything and the map sensor was messed up but I fixed that and then this problem came up.
Old May 30, 2008 | 06:44 PM
IOSUA's Avatar
mmmm... check for vaccum leaks. if you changed the map sensor, maybe you forgot to put back the little O ring. dubble check it. LMK
Old May 30, 2008 | 06:47 PM
on my map sensor I dont think there is any o rights. Its a block sensor mounted on my firewall ran by vacuum line. I didnt do anything with the lines anyways just the connect for the signal. This sucks, I have no idea how to fix it and its not driveable...
Old May 30, 2008 | 07:18 PM
IOSUA's Avatar
yeah man i dont know what else off the top of my head. i would just check the vaccum lines, spark plugs, firing order. other then that, i dont really know..
ANYONE ELSE KNOW WHAT THIS GUY COULD DO TO FIX HIS PROBLEM??
Old May 30, 2008 | 10:35 PM
checked the vacuum lines. Replaced the spark plugs with colder new plugs and it shouldnt be off timing.
Bump..I need help
superhatchbackbros
Oct 7, 2006 11:07 AM
spooncivic99
12
Feb 19, 2006 06:16 PM
lscivc
Feb 19, 2005 08:04 AM
