distributor advance
Old May 30, 2008 | 05:22 AM
dcomer04's Avatar
Default distributor advance
I've got the crank at TDC and the cam gears are lined up.
But when i advance the distributor all the way, the crank still doesn't reach the 16º mark.
It goes to about 13º
How do i fix this????
i've got a b16
Old May 30, 2008 | 08:33 PM
inspyral's Avatar
Have you done any work around the cams or timing belt recently? Are you absolutely sure the cams and crank pulley are lined up correctly? How are you getting your timing readings? Is the engine idling normally at ~800RPM? Are you sure your timing light is in good working order?
92gsrdb2
Aug 11, 2012 09:01 PM
dannyk89
Nov 4, 2008 08:16 AM
thomas1214
Apr 1, 2008 12:05 AM
b204dr
Jun 16, 2005 09:46 AM
