Chips, ECUs and the rev limiter
Old Jul 16, 2002 | 07:01 AM
Watkinsm3's Avatar
Default Chips, ECUs and the rev limiter
Ok... with a stock GS-R motor can you safely raise the limiter (via Chip/ECU upgrade). How high can you go without having to worry about problems (valve float... etc)? Reputable companies to talk to? Programmed versus reprogramable chips?
I run in SCCA Street Prepared so I can't touch the engine internals...
Old Jul 16, 2002 | 02:32 PM
IN VTEC's Avatar
Default Re: Chips, ECUs and the rev limiter (Watkinsm3)
I'd be interested in hearing this.
I believe Greg Samaroo (CHEETAH) knows somebody in his locale that did (does?) rechipping of ECU's for higher rev limits and VTEC x-overs.
Locash racing's name has also been tossed around a couple of times over the last couple of years on this board as ECU chippers.
C-Speed Racing also advertises ECU rechipping, but I e-mail'd them and there was no response. I'm wondering if C still does ECU's, especially with their emphasis now on Hondata.
Old Jul 16, 2002 | 03:57 PM
mattL's Avatar
well chipping a stock motor wont really create any power. this is because the purpose of altering the computer is to work better with the mod's done to the car, you might be able to squeeze a horse or two out, but i wouldnt raise the rev limiter any more than 3-4 hundred rpm's
edit: just realize you have a 2000, i would recomend converting to OBDI, for 2 reasons 1 you will get more power 2 you cant chip your ecu
[Modified by mattL, 12:58 AM 7/17/2002]
Old Jul 17, 2002 | 05:59 AM
Watkinsm3's Avatar
Default Re: Chips, ECUs and the rev limiter (mattL)
Unfoturnatly I can't convert to OBDI and remain legal in my class. What about replacement ECUs?
Old Jul 17, 2002 | 06:08 AM
Muckman's Avatar
Moderator in Chief
If your stuck with stock GSR cams then raising your rev limiter wont help you much. Like MattL said you may get 1 or 2hp max. Maybe you can play around with a VAFC and adjust your fuel map as well.... just a thought.
[Modified by Muckman, 10:10 AM 7/17/2002]
Old Jul 17, 2002 | 07:15 AM
Watkinsm3's Avatar
Default Re: Chips, ECUs and the rev limiter (Muckman)
actually gaining horsepower is not the number one thing on my mind for this modification. Most Autocrosses are run in 1st & 2nd gear. I effectivly shorted my gearing (with shorter wheels & tires) so my second gear now maxs at about 59-60MPH. I want to keep the acceleration advantage of the shorter tires but gain some length back in second gear. With the extra revs I'll spend less time on the rev limiter in second and hopefully avoid the time consuming shift to third. Its amazing but an extra 2-4 mph will make a huge difference. I'm just concerned if the engine can take it...
Old Jul 29, 2002 | 07:57 AM
Watkinsm3's Avatar
Ok... It's been a while but I did some research and I CAN update(backdate?) my ECU to OBD I. What routes are available to me with the OBD I ecu? Unfortunatly trhe car's not quite finished yet. I'm allowed simple bolt on parts( I/H/E, throttle body, intake manifold, cat, pullies... ) in my class just no interior engine work. no cam gears.
Is there anything available that will allow easy modification of the ecu after more work is done? example : I have I/H/E now... I'm looking at a new intake manifold with independent throttle bodies this winter.
Just looking for any thoughts... ideas...
Old Jul 29, 2002 | 08:29 AM
bulldog_RS20's Avatar
I'd throw this over to the Comp forum. Many auto-xers over there who may be of help. Godd topic also...
Old Jul 29, 2002 | 08:57 AM
Watkinsm3's Avatar
Default Re: Chips, ECUs and the rev limiter (bulldog_RS20)
Thanks for the advice... will do!
superbeastcrx
Sep 17, 2005 07:20 AM
CrxSiRyder
Apr 29, 2005 10:51 AM
AkEuro_R
Apr 27, 2004 04:00 PM
kasper
May 19, 2003 12:09 PM
94dxt
Mar 26, 2003 03:29 PM
