94 civic dx wont start
Old May 29, 2008 | 12:27 PM
hugz4me's Avatar
Default 94 civic dx wont start
drove to church today no problems got ready to leave wouldnt start. I figure maybe its out of gas so I add 1 gallon of gas and it still wont start.
Old May 29, 2008 | 12:34 PM
civic_hatch24's Avatar
Default Re: 94 civic dx wont start (hugz4me)
check the starter or distributor
Old May 29, 2008 | 12:35 PM
iluvmy2000civicex's Avatar
Is it all the way in park?
Old May 30, 2008 | 06:51 AM
hugz4me's Avatar
Default Re: 94 civic dx wont start (iluvmy2000civicex)
its a manual transmission
Old May 30, 2008 | 06:56 AM
1CaMw0nDeR's Avatar
Gonna need some more info dude... Does it turn over just not catch..?? How up to date are u on plugs, wires, cap, rotor..?? Is the starter-wire connected since they sometimes pop off after a lil rough driving..?? Did you check your fuses and/or ignition switch harness..?? Could be about 20 diff things i'm just tryna give ya the shake down so we can see wassup...
Feel honored to have been blessed with my 100th post also lol...
Old Jun 2, 2008 | 06:15 AM
hugz4me's Avatar
OK found out the plugs were bad they were so old Moses probably helped install them. So had all 4 plugs replaced w/premium bosch plugs...now its overheating. Tried bleeding the system, no luck. The upper hose gets hot not lower. Previously replaced rad, & cap, & therm this wasn't happening prior to replacing plugs. FYI I got this car 94 civic dx from my brother who did little or no maintenance. Don't want u guys to think I'm a total idiot.
Old Jun 2, 2008 | 06:45 AM
1CaMw0nDeR's Avatar
does it leak coolant at all..??
Old Jun 2, 2008 | 07:29 AM
hugz4me's Avatar
Default Re: 94 civic dx wont start (1CaMw0nDeR)
No it doesnt leak coolant
I noticed this morning the top to overflow was very loose
I tightened it prior to bleeding system, still runs hot.
Old Jun 2, 2008 | 07:33 AM
1CaMw0nDeR's Avatar
do u have any idle issues??
Old Jun 2, 2008 | 07:57 AM
xJ.SLOTHx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hugz4me &raquo;</TD></TR><TR><TD CLASS="quote">drove to church today.</TD></TR></TABLE>
thats your problem right there
Old Jun 2, 2008 | 09:08 AM
hugz4me's Avatar
Default Re: 94 civic dx wont start (xJ.SLOTHx)
no idle issues
Old Jun 2, 2008 | 09:09 AM
hugz4me's Avatar
whats my problem?
Old Jun 2, 2008 | 09:56 AM
1CaMw0nDeR's Avatar
try a new thermostat first, and if that doesn't work, try a radiator flush.. could be clogged up possibly..
Old Jun 2, 2008 | 10:05 AM
hugz4me's Avatar
already has new therm
will try flush...thnx
Old Jun 2, 2008 | 10:35 AM
1CaMw0nDeR's Avatar
Yeah i'd definitely try the radiator flush than, ya never know when that things gettin clogged up, and if u live in a semi-warm environment and your lower radiator hose isnt getting hot, than either A. Thermostat is busted B. Radiator is busted or C. Its like 5 degrees out where u live and ur thermostat serves no purpose lol....
Old Jun 3, 2008 | 05:10 AM
hugz4me's Avatar
I did the flush and so far so good
thanks for your help
Jegacy1396
Feb 17, 2017 08:29 AM
mikedaruto
Jun 26, 2012 12:14 PM
Heeter
Classic Hondas
Apr 21, 2009 12:56 PM
tarheeler
May 18, 2005 06:19 PM
CWITR
May 3, 2005 04:38 PM
