ALL KINDS OF PISSED!!
Ok here's the Issue i have a Greddy turbo kit for a 2000 civic EX wich i bought for the hatch from a friend who had wrecked his car. So i find out that the wastegate is bent but all else is ok. SO here's the problem I CAN NOT FIND A STOCK REPLACEMENT OR AFTERMARKET INTERNAL WASTEGATE ANYWERE!! EVEN GREDDY THEMSELVES CANT GIVE ME A STRAIGHT ANSWER OR AT LEAST A FREAKIN PART NUMBER!! Loosing my mind here peep's any idea's will be appreciated........ and i would like to keep this system and stock as i can it's turboed daily driver haha
Sorry i tried editing the thread title i guess i dont have authorization to perform that. but i dont want to run a external wastegate because i am still running a a/c system. also i would have to get a different manifold and all sorts of stuff not looking to go that route
Just about any WG actuator will work, most have the correct threads, or if you use the whole thing, they have the same endlink hole size. You'll just have to make a mounting adapter if the arm is longer/shorter.
BTW some guy on HMT used a carb return spring and a chain since the WG arm wasn't long enough.
Modified by HiProfile at 8:08 PM 5/29/2008
These guys make aftermarket replacements for internal wastegated turbo's...
http://www.forgemotorsport.com...=0001
But as mentioned you can just use a dif. used one or go external as long as you plug/block the internal wastgate.
tegon-gsr
Jan 28, 2005 06:10 AM
Chris F
Jul 23, 2004 03:50 PM
