ALL KINDS OF PISSED!!
Old May 29, 2008 | 12:00 PM
sMoKe_RoCkS's Avatar
Default ALL KINDS OF PISSED!!
Ok here's the Issue i have a Greddy turbo kit for a 2000 civic EX wich i bought for the hatch from a friend who had wrecked his car. So i find out that the wastegate is bent but all else is ok. SO here's the problem I CAN NOT FIND A STOCK REPLACEMENT OR AFTERMARKET INTERNAL WASTEGATE ANYWERE!! EVEN GREDDY THEMSELVES CANT GIVE ME A STRAIGHT ANSWER OR AT LEAST A FREAKIN PART NUMBER!! Loosing my mind here peep's any idea's will be appreciated........ and i would like to keep this system and stock as i can it's turboed daily driver haha
Old May 29, 2008 | 12:06 PM
Horseofcourse's Avatar
Default Re: ALL KINDS OF PISSED!! (sMoKe_RoCkS)
Im not positive but couldnt you just run an external waste? and i would edit the caps out of your title before your thread gets locked/deleted
Old May 29, 2008 | 02:39 PM
Default Re: ALL KINDS OF PISSED!! (Horseofcourse)
Sorry i tried editing the thread title i guess i dont have authorization to perform that. but i dont want to run a external wastegate because i am still running a a/c system. also i would have to get a different manifold and all sorts of stuff not looking to go that route
Old May 29, 2008 | 04:51 PM
I have an external wastegate on mine... i have a/c. look at wastegate elbow
Old May 29, 2008 | 04:54 PM
HiProfile's Avatar
Just about any WG actuator will work, most have the correct threads, or if you use the whole thing, they have the same endlink hole size. You'll just have to make a mounting adapter if the arm is longer/shorter.
BTW some guy on HMT used a carb return spring and a chain since the WG arm wasn't long enough.
Modified by HiProfile at 8:08 PM 5/29/2008
Old May 30, 2008 | 08:13 AM
Default Re: ALL KINDS OF PISSED!! (HiProfile)
Coo ill see if i cant find one in a junk yard. Ive seen a couple on Ebay maybe ill just order one of those
Old May 30, 2008 | 08:17 AM
whats up with these dual port actuators?
Old May 30, 2008 | 08:48 AM
Fo-Do Fanatic's Avatar
Default Re: (sMoKe_RoCkS)
or you can just convert it to an externally gated turbo......
Old May 30, 2008 | 01:51 PM
NonovUrbizniz's Avatar
Loved
Default Re: (Fo-Do Fanatic)
These guys make aftermarket replacements for internal wastegated turbo's...
http://www.forgemotorsport.com...=0001
But as mentioned you can just use a dif. used one or go external as long as you plug/block the internal wastgate.
Old May 30, 2008 | 02:54 PM
rorik's Avatar
What kind of turbo does the kit come with? I bet it would be easy enough to get a new wastegate actuator.
Old May 30, 2008 | 09:55 PM
blinx9900's Avatar
Default Re: (rorik)
i have one, pm'd.
Old May 31, 2008 | 10:06 AM
Default Re: (blinx9900)
PM replied, its a TD04H-19T turbo
blueintegra
Apr 13, 2008 06:24 PM
blueintegra
Apr 10, 2008 08:53 PM
ridin98civic
May 26, 2007 08:20 PM
tegon-gsr
Jan 28, 2005 06:10 AM
Chris F
Jul 23, 2004 03:50 PM
