Intake
Old May 29, 2008 | 11:41 AM
sd_ej1's Avatar
Default Intake
Need some help deciding which intake i should get.
I have a injen short ram on my gsr
is the password jdm intake a better intake ???
Old May 29, 2008 | 12:03 PM
sjbmx's Avatar
its not gonna be that much better and mostly your just paying for the name. i woundnt even have got the injen one. no name pipe and k&n filter are the best in my opion
Old May 29, 2008 | 12:11 PM
sd_ej1's Avatar
Default Re: (sjbmx)
thanks bro.
Im just getting the new intake for my smog.
my intake dosent match because i got da intake from my cousings si
Old May 29, 2008 | 02:25 PM
batallic's Avatar
get one from ebay jsut use a good filter and call it a day
Old May 29, 2008 | 08:15 PM
inspyral's Avatar
Default Re: (sd_ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sd_ej1 &raquo;</TD></TR><TR><TD CLASS="quote">thanks bro.
my intake dosent match because i got da intake from my cousings si</TD></TR></TABLE>
If CARB legality for smog is your primary concern then I would just get the cheapest shortram intake you can find that's specific to your application and comes with a CARB E.O. #/sticker. As far as I know, the Password JDM intakes are not CARB certified. Of course, you could also look on craigslist, etc for an OEM GSR airbox which would obviously pass the smog visual inspection, and should also be fairly cheap.
Old May 31, 2008 | 09:48 PM
sd_ej1's Avatar
Default Re: (inspyral)
Cool thanks you guys i had all those things in mind.
now to c which intake i find first
Old Jun 1, 2008 | 01:43 PM
Dark@Powers's Avatar
Just throw on an OEM for the pass, and get a hybrid intake ie. Comptech Icebox.
Old Jun 1, 2008 | 02:44 PM
brian_98EK's Avatar
intakes are all generally the same. buy the cheapest one you can find it will do the same job just as good.
pos_cd5
Honda S2000
Jul 10, 2006 10:10 AM
