can i make a D16Y7 a 14 sec. all motor???
Old Jul 16, 2002 | 01:50 AM
abs0lutexer0's Avatar
Default can i make a D16Y7 a 14 sec. all motor???
i have a 97 civic sedan DX, since i dont want to spend so much on a new motor and labor, im planning to keep the DX engine. however i dont want go turbo, supercharge or NOS, i want to make it a D16 all motor. im planning to do a lot of internal engine work and gutting my car in order to make it a 14 sec car. do you guys think its possible for an all motor D16Y7 to run 14s???
Old Jul 16, 2002 | 02:00 AM
pLaYbOi's Avatar
New User
Default Re: can i make a D16Y7 a 14 sec. all motor??? (abs0lutexer0)
itll cost more going all motor than fi with ur motor..
just a thought..
Old Jul 16, 2002 | 02:25 AM
Mista Bone's Avatar
D Tranny Guru
not very likely being a 6g coupe. A 5g hb would stand ALOT better chance.
Old Jul 16, 2002 | 04:16 AM
EKB18BPR3's Avatar
Default Re: can i make a D16Y7 a 14 sec. all motor??? (Mista Bone)
without somesorta forced induction d16 all motor wont reach 14's. unless u do somesorta swap/mini-me/hybrid. header, CAI, exhaust/catback alone wont make ur car go 14's.
Old Jul 16, 2002 | 04:31 AM
vtechatch's Avatar
Default Re: can i make a D16Y7 a 14 sec. all motor??? (dniedacess)
Get the most aggressive Cam from Web Cam or Gude
Get an Ecu with a Rev limit of about 8500
Get an Upgraded Valve Train with the Cams
A Header
Exhaust
And You should be there,but you might be sitting on a milk crate steering with Vise Grips to get there.
Old Jul 16, 2002 | 04:48 AM
Mista Bone's Avatar
D Tranny Guru
D16Z6 with boltons running 14.85?????
It was a stock block!!!!!!!!!!!!
Old Jul 16, 2002 | 05:03 AM
vtechatch's Avatar
I seen you on Crxresource.I thought you had a DX motor at one time tho.
Dan
Old Jul 16, 2002 | 05:26 AM
sohc_boy's Avatar
tranny swap, the 92-95 si/ex or 96-00 ex, that will help alot.
Old Jul 16, 2002 | 05:46 AM
Thirty-Nine's Avatar
bilthatch has a D16Y7 engine (with a lot of work done to it) and he runs high 13s (with a small shot of nitrous as his sig says).
Old Jul 16, 2002 | 05:48 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: can i make a D16Y7 a 14 sec. all motor??? (vtechatch)
had a D15B7 running 15.08, now running a little bit faster with Z6 power.
Old Jul 16, 2002 | 03:54 PM
johnnyblaze's Avatar
I have seen 13 sec without turbo. I dont know how.
Old Jul 16, 2002 | 04:35 PM
.hugo's Avatar
You'd get more better results swapping in a d16y8 or d16z6. And it would be cheaper, because a lot of work will need to be done to the dx motor.
steede
Aug 20, 2009 11:52 AM
1995Civiccx
Oct 11, 2006 10:21 AM
mike84 CRX-GTL
18
Mar 18, 2006 09:20 AM
codyb13
Oct 14, 2005 10:13 PM
StraightCivic
Apr 15, 2005 12:52 PM
