adjustable cam gears and base timing
Old May 28, 2008 | 05:08 PM
RTW DC2R's Avatar
Default adjustable cam gears and base timing
so this motor I picked up has adjustable cam gears. it looks like the cams (center section of the cam gear) are adjusted about 1 or 2 degrees toward the front of the car (advanced?). how does that effect the base timing of the motor? If I set the base timing at 18deg, does that mean the timing is really advanced 19 or 20 degrees? this is also on a stock ECU which I dont think matters but just more info for ya.
Old May 28, 2008 | 05:51 PM
Jdm_jay's Avatar
Default Re: adjustable cam gears and base timing (RTW DC2R)
well it just means that the cams are advanced the bas timing would be whatever u set it to. usually without a ecu tune on a stock ecu u should advance the intake cam by 1 degree and retard the exhuast cam by 1 degree. u wont really notice any big power gains since the car is not tuned are everything else is stock.
so good luck with that.
Old May 28, 2008 | 06:00 PM
RTW DC2R's Avatar
Default Re: adjustable cam gears and base timing (Jdm_jay)
im not trying to tune it. i want it to run safe. dont want timing too advanced or too retarded.
Old May 28, 2008 | 06:37 PM
Mashimaro's Avatar
i wouldn't adjust them too much unless you've measured valve-to-valve clearance. there's a chance that you can smack the valves together if you play with the gears too much...
Old May 28, 2008 | 06:43 PM
R.Kelley's Avatar
Default Re: adjustable cam gears and base timing (Mashimaro)
just slap some stock cam gears on it
Old May 28, 2008 | 07:12 PM
totsie7944's Avatar
Why not just loosen the cam gears, set them to zero, check TDC and run that way? Its what I've always done before getting tuned with Jeff with my Toda adjustables and last time he didn't even change anything at all.
Old May 28, 2008 | 09:07 PM
itr1244's Avatar
Default Re: adjustable cam gears and base timing (R.Kelley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R.Kelley &raquo;</TD></TR><TR><TD CLASS="quote">just slap some stock cam gears on it</TD></TR></TABLE>
or adjust it back to zero
Old May 29, 2008 | 08:15 AM
RTW DC2R's Avatar
because the adjustment bolts are stripped. and I dont have any stock gears laying around.
Old May 29, 2008 | 08:39 AM
Dave_B's Avatar
Default Re: (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">because the adjustment bolts are stripped. and I dont have any stock gears laying around. </TD></TR></TABLE>
I "might" have a set laying around. I'll check the shop and let ya know.
Old May 29, 2008 | 09:05 AM
CW-ITR's Avatar
92DAB16A
Feb 29, 2012 09:40 PM
neoc03
Jul 18, 2007 08:09 AM
[HrZn]4life
May 13, 2003 03:17 PM
Jockobo
Jan 23, 2003 03:48 PM
