8**V-AFC Hack...now bad idle??? HELP!!***
Old Jul 15, 2002 | 11:28 PM
boostinb18's Avatar
Default ***V-AFC Hack...now bad idle??? HELP!!***
hey everyone put my 450cc DSM injectors on today with my VAFC and i put the settings to -40% 1000-5000 rpms then -35% from 5000-7000 rpms and now the idle is pretty ruff and drops pretty low and seems like it wants to die?? what could this be...any ideas on different settings and the injectors are ticking kinda loud....anyway to quiet them down??......and should i leave my check valves in??? my FMU??? my inline pump????
when i closed off the check valves the car would start to bogggg at 4000 rpms....it wouldnt let it go higher but only when i was on it!
thanks!
[Modified by boostinb18, 8:29 AM 7/16/2002]
Old Jul 16, 2002 | 12:05 AM
Tomek's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (boostinb18)
you need to ditch the fmu and check valves....this link will explain the hack some more incase you havent seen it. http://www.thedropshop.tv/vafc.htm
Old Jul 16, 2002 | 07:37 AM
boostinb18's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (AztecEJ)
yah i have my hack set to the drop shops settings....i just wanted to see what other people were running......and what was happening when i closed off my check valves???? thanks!
Old Jul 16, 2002 | 08:06 AM
zojirushi's Avatar
make sure the afc is correctly installed and working... Sounds like its not.
Old Jul 16, 2002 | 09:03 AM
legendboy's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (zojirushi)
any benifit to installing my dsm's with my safc before I put my turbo on?
Old Jul 16, 2002 | 05:31 PM
boostinb18's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (legendboy)
i installed it according to the instruction book.....and it seems to be working fine.....the readings and correct, like the throttle %'s and the RPM's..........and when i am idleing my vacuum on my gauge will drop to about 14 in.hg and the cars idle will drop to about 550 and almost die then pop up to 1100 then slowly go down to 750-800 like it normally is then it will be fine for like a minute! what could be causing this??? could it be cause i am still running my inline pump, my check valves, and my FMU??? thanks!!!!
Old Jul 16, 2002 | 05:48 PM
boostinb18's Avatar
ttt
Old Jul 16, 2002 | 06:07 PM
B18C-RnVA's Avatar
New User
just a little quick question can you use the fields for the hack
Old Jul 16, 2002 | 06:21 PM
rioninja's Avatar
Easy fix:
richen the trim up a bit at the 1k range. I have mine at -25%, but just go up 5% at a time until it smooths out.
Old Jul 16, 2002 | 07:11 PM
BoostedSi's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (RioNinja)
Ditch that inline and see what happens, thats what my guess would be. You dont need a fmu or inline and check valves if your running no more than 10psi with the 450's and hack.
Old Jul 16, 2002 | 08:43 PM
SlowB16's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (BoostedSi)
take the inline and the fmu off, get rid of it. the check valves should be ok though
Old Jul 16, 2002 | 09:22 PM
turbod97ex's Avatar
New User
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (SlowB16)
You don't need the check valves either according to https://honda-tech.com/zerothread?id=137901
Also, on the dropshops web site, it says "Stock Honda MAP sensor utilized ( no check valves or missing link sort of devices needed for boost up to 10psi w/o CEL)"
Were you folling the instructions off of that site?
[Modified by turbod97ex, 12:30 AM 7/17/2002]
Old Jul 16, 2002 | 09:28 PM
dbman96's Avatar
New User
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (turbod97ex)
You MUST ditch the check valve or the AFC hack is worthless and you'll lean out really bad under boost. The FMU is also not needed, and this in combination with the inline pump is almost DEFINITELY running your fuel pressure too high at idle and causing you to be too rich down low. Ditch the pump, FMU, and check valve and call us in the morning.
Old Jul 17, 2002 | 04:41 PM
boostinb18's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (dbman96)
alright thanks guys!!! ill try this stuff out tomorrow......hopefully it will run better! thanks!!!
Old Jul 24, 2002 | 10:20 AM
Reid's Avatar
Global Moderator
Nope.
DC2 = GSR/ITR
DC4 = LS/RS/GS
[Modified by Reid, 11:57 AM 7/24/2002]
Old Jul 24, 2002 | 10:28 AM
servion's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (Reid)
can we do this with the fields?
Old Jul 24, 2002 | 10:33 AM
zojirushi's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (servion)
you said the injectors are ticking..... maybe they're bad.
Old Jul 24, 2002 | 12:04 PM
TurBoXBirD16's Avatar
how did everything go once u ditch the FMU, checkvalues??
do u guys think i will need a inline pump for 7 psi with this hack??
Old Jul 24, 2002 | 01:24 PM
Mr. Softee's Avatar
Default Re: ***V-AFC Hack...now bad idle??? HELP!!*** (xbird)
if you are using the 440 or 450cc injectors... you can just use your stock fuel pump. The fuel pressure is going to be the same, the injectosr just flow a lot more.
Old Jul 24, 2002 | 01:48 PM
Default !
thx!
Old Jul 24, 2002 | 02:42 PM
boostinb18's Avatar
Default Re: ! (xbird)
alright i pulled off the FMU, the check valves, and the inline pump....and for some reason my car's fual pressure was at 50psi stock!! i dont know why, but anyways i put on my B7M FPR and turned down the fpr to 42 psi at idle with vacuum on it, and i set my vafc sttings to -40 at 1000, -38 2000, -35 the rest, and WOW!!! it pulls so much harder!!! and im only at 6 psi! there is actually some top end pull now! but the problem is i am still throwing cel's for my O2!! i got it rewelded closer to my turbo about 5-6 inches down from the turbo and it still throws cel' and my air/fuel doesnt read....so im thinking the sensors bad already! i only bought it like 4000 miles ago!!! there goes 40 bucks! well anyways im gonna get a new o2 and then ill se if it helps some more!!!
thanks a lot for all your help!!! i am actually pretty happy wiht my car now! and the vafc is great once you figure out to tune it!
Old Jul 24, 2002 | 03:07 PM
Default Re: ! (boostinb18)
oh that's good to hear
but u still need the fpr to adjust it... maybe it's probably ur O2 is not working good and the ECU is messing the fuel pressure...
u probably wont need the FPR after you fixed ur O2
good luck
are u going to go higher boost?
Old Jul 24, 2002 | 03:43 PM
tonydatyga's Avatar
are you running hot? b/c the ecu will dump fuel to cool down combustion chamber temp.
Discosteak
Sep 9, 2005 08:13 AM
slowsi00
Oct 10, 2002 12:48 PM
deacs
Sep 20, 2002 12:26 PM
slwazgsr
Aug 27, 2002 03:19 AM
