i accidentally found this out
i drive an ep3 and i found out that i was STILL able to put into neutral from any gears without engaging clutch... im sure that this is not good for my gear.. but can someone tell me if it is supposed to be like this....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">You can do that with any manual car. Completely normal.
You can also shift into another gear if you rev match.
yeah, REV matching is an artform. but you need the right vehicle
i had a chevy spectrum...and a chevy S-10 that i could go threw ALL the gears without using the clutch.
i shift at too high of RPMs to even try on the ep3
</TD></TR></TABLE>yeah, REV matching is an artform. but you need the right vehicle
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">You can do that with any manual car. Completely normal. You can also shift into another gear if you rev match.
LOL, I do this all of the time in my truck at work.
</TD></TR></TABLE>LOL, I do this all of the time in my truck at work.
good to read this because today i almost went from first to second without pushing in the clutch. and i got scaredd
Also why do you need to push in the clutch while braking....?
You only need to clutch when braking if you are coming to a stop or near-stop. Otherwise the motor will stall. Think about it...
As for going from a gear into neutral without the clutch, I do it all the time and have always done it. You sorta need to rev match, but not as much as actually shifting gears clutchless.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mormonboy »</TD></TR><TR><TD CLASS="quote">this thread is full of FAIL! </TD></TR></TABLE>
How is that?
A guy had a question and it was answered. Sound kind of like the goal around here.
How is that?
yeah, if you want to go FWD, Shiftless... GET A NEW COBALT SS!!!! FTW!
seriously...
"WOT and no-lift shift" allows maximum performance – upshifts can be performed very quickly without lifting the throttle. An algorithm in the engine's controller enables this high-performance feature to shut off the spark to any cylinder, resulting in a small "pop" noise heard between shifts.
....wish mine had that
(and the 260 hp turbo'd 2.0!)
anyone looking for a riced out ep3 for about 14K!!!
LOL, nah!
seriously...
(and the 260 hp turbo'd 2.0!)anyone looking for a riced out ep3 for about 14K!!!
LOL, nah!
How is that? A guy had a question and it was answered. Sound kind of like the goal around here. </TD></TR></TABLE>
because shifting without using the clutch is t00 fast n furi0us for j00!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 »</TD></TR><TR><TD CLASS="quote">As for going from a gear into neutral without the clutch, I do it all the time and have always done it. You sorta need to rev match, but not as much as actually shifting gears clutchless. </TD></TR></TABLE>
How do you rev match going into neutral? You can let off the throttle, but you sound like you are talking out of your ***. F minus on your report card. Go home.
because shifting without using the clutch is t00 fast n furi0us for j00!! </TD></TR></TABLE>
Nobody said shifting without the clutch is faster. It's definitely slower. You're just an *******.
lmao!
lmao!
bwhahaha...
bwhahaha...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">Nobody said shifting without the clutch is faster.</TD></TR></TABLE>
So you 2 are laughing at nobody.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEN_ONE »</TD></TR><TR><TD CLASS="quote">
How do you rev match going into neutral? You can let off the throttle, but you sound like you are talking out of your ***. F minus on your report card. Go home.</TD></TR></TABLE>
Give it a little gas when going from a gear into neutral (without using the clutch). Try it out and you'll see what I'm talking about. Often times you can't just stick it into neutral--you need to blip the throttle a little.
After you do so, call yourself a douchebag for talking about stuff you don't know about.
no they are laughing at you cheese boy. and so am I. You are an idiot.
</TD></TR></TABLE>no they are laughing at you cheese boy. and so am I. You are an idiot.
philkehn
Oct 27, 2006 06:58 AM
