D16 Turbo Oil feed line help
im new here, im trying to do my first attempt in turbocharging. I'm installing a turbo on a d16xx and my turbo kit came with no oil feed nor return lines, i was wondering if any one had any tips on how to fabricate one, or i was also looking in to going with a kit, i was wondering what would be better and or cheaper? also i was wondering if any one had any tip on fuel correction to compensate for the soon to be boost,,,
Get an oil feed/return line kit from Stealthmode. Check http://www.tunertoys.com and you should have everything you'd need.
What do you mean by fuel correction? Like what will you need? Is you motor stock?
yeah thats what i was thinking, i was looking at there kits, now i have a t3/t4 turbo so would that mean i have to get the stealthmode 1/4 or the 1/8 kit? does any body know?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk »</TD></TR><TR><TD CLASS="quote">Buying a premade kit will save you time and the hassle unless your in a hurry. You can some times make the lines at a local hose/fitting supplier but they probably wont have the flanges that you'll need.</TD></TR></TABLE>
Very true.
My return line was made out of extreme high temp 3 poly hose...i didnt even use the steel braided (I forget why). It worked great!
Very true.
