replaced axle, now car wont move?
Old May 28, 2008 | 09:58 AM
jdmhonDAftw's Avatar
Default replaced axle, now car wont move?
I have a 93 civic with a 96 jdm gsr swapped in. Not to long ago i broke a axle off right at the tranny, the broken piece was flush with the opening of the tranny. I tried taking off the other side of the axle and with skinny pieces of metal pushing it out. I then drilled and tapped the broken axle piece and got it out this wa. I replaced the axle.
Now my question is, now the car doesnt drive. i put it in gear and it goes no where. Did i break something in my tranny?
Old May 28, 2008 | 10:58 AM
OMGWTFBBQ!'s Avatar
Default Re: replaced axle, now car wont move? (jdmhonDAftw)
It sounds like your axel isn't fully pushed into your transmission. Try pulling it out and adjusting the locking clip at the end of the splines to make it easier to push the axel all the way in.
Old May 28, 2008 | 07:22 PM
strategy400's Avatar
Default Re: replaced axle, now car wont move? (OMGWTFBBQ!)
Make sure the splines aren't stripped in the hub or worse... diff...
I would think the spider would be in the way if you tried to knock the axle out from the other side. If the spider is missing/mislocated it won't go.
Hopefully it doesn't look like this:
Maybe something else broke.
Hopefully its a stripped hub or some other simpler problem.
Good luck.
Old May 29, 2008 | 12:57 AM
obuhmyuh's Avatar
Default Re: replaced axle, now car wont move? (strategy400)
make sure the CV assy. its completely seated in the tranny. maybe a piece of ur old axle is stuck in there somewhere.
xingyun
Nov 30, 2008 02:06 PM
vanmaster420
Mar 4, 2007 09:29 PM
See Are X
Apr 28, 2006 07:42 PM
The Phil
Aug 26, 2005 10:33 PM
tallblondkid
18
Jul 26, 2004 08:10 AM
