What turbo?
Old May 28, 2008 | 09:15 AM
playa192's Avatar
Default What turbo?
So i have an H23. What turbo should i get and around what psi should i run to get 300 whp on a stock block. It will be professionally tuned. also if it is possible can i keep my ac?
Old May 28, 2008 | 09:23 AM
vlang29's Avatar
Default Re: What turbo? (playa192)
https://honda-tech.com/zerothread?id=783372
https://honda-tech.com/zerothread?id=316373
all in the faq
https://honda-tech.com/zerothread/2168311
Old May 28, 2008 | 09:35 AM
playa192's Avatar
yeah i have looked at those but none of them really completely answered my question.
Old May 28, 2008 | 10:56 AM
vlang29's Avatar
there are so many different factors that come into play when deciding which turbo and what psi to run, nobody can just tell you what to do. You have many options. It isn't need for speed where you just buy a stage one or two kit. If you read enough, you will learn what you need to know. There is no "best" turbo, and absolutely in no way can anyone just tell you what psi you should run. 8psi may be safe on one turbo, and instant catastrophe on another. Read turbo build threads. Read about different peoples build experiences, that will help you make the decision for yourself. If you seriously can't decide which turbo you want with all the information avaliable on the internet, you probably shouldn't be attempting to turbo your car
keeping your a/c depends if you can get a manifold that will have enough clearance. there are hundreds of different exh manifold designs.
Old May 28, 2008 | 12:09 PM
subydoored's Avatar
Default Re: What turbo? (vlang29)
borg warner s200 7 psi to 10 psi...... there
zeusdavis
Aug 23, 2010 04:43 AM
pnk_03
Apr 3, 2008 11:41 PM
iluvdrt
Oct 29, 2003 07:18 PM
scooter
Jul 15, 2002 09:40 PM
