PLEASE HELP Check engine light come on after Vtec kicks in
I have been running my JDM B16A with my DX ECU for a bit while waiting for the JDM P30 ECU to come in. With my DX ECU, there is no check engine light come on or anything like that but after i switch the ECU to the JDM P30 ECU then after the vtec kicks in the check engien light will come up, if i don't rev it up more than 3 or 4K RPM then the light won't come up also. Please help me figure out what is the problem??? also i did run the vtec wire from the engine to the A4 wire in the ECU.
well the only solution is to stop hitting VTEC dumbass.... j.j sell the car or burn it and call your insurance ...
there is two plug under the pass. kick panel..could be hiding under the glove box..i should be two plug that's held by a green plastic piece if i'm not mistaken..
springfieldcivic
15
Jun 24, 2005 02:26 PM
