Lost headlights and all dash lights
Old May 27, 2008 | 09:27 PM
jacksonww's Avatar
Default Lost headlights and all dash lights
Is the main fuse box under the hood the problem? I see one labled "Light" or "Lights". It's a 40 AMP fuse that appears to be bad.
Turn signals work as well as the brake light but nothing else.
Thanks.
Old May 28, 2008 | 07:02 AM
wiZCo's Avatar
Stouts 'n' Scotch
Well, it sounds like you need to replace the fuse.
Also, check the cabin fuse panel, the dash lights use a 20A fuse that's probably blown as well.
Old May 28, 2008 | 07:03 AM
randY49's Avatar
Default Re: Lost headlights and all dash lights (jacksonww)
I believe the interior lights are under the steering wheel in the interior set of fuses. Just pop off the panel and everything should be labeled.
The dash lights are on the same circuit as the parking/tail lights and the headlights are separate.
I had this happen just about a month ago. Mine turned out to be a bad switch on the column. If you flip the headlight/parking light switch a couple of times really fast, it might clean the connection enough to where you can get them to work. That is what I did.
Old May 28, 2008 | 08:29 AM
jacksonww's Avatar
Yup - It was the 40 amp block fuse under the hood. I now have headlights, foglights, dashlights, the clock works, and most important, the hatch open light is not on.
shamu1
Jan 30, 2012 05:25 PM
2.2accord
Jun 9, 2011 07:50 AM
cor4ey
Apr 16, 2010 03:53 AM
Luke G.
10
Sep 27, 2009 08:32 AM
808EK4
Oct 27, 2007 03:30 AM
