honda expert i need help
Old May 27, 2008 | 06:24 PM
tpham_autotecks's Avatar
Default honda expert i need help
i swapped the ls to my crx, i did replace new thermostat and aluminum radiator, i did bleed the air out from the cooling system, i did check cooling fans operated, everything was fine at idle, then i took it out to test drive for awhile 30min approx with 40-60 mph, then my lower radiator hose got cold and pressuried to the radiator cap and made my coolant reservoir boiling and spilled out, i have no white smoke
any idea?
Old May 27, 2008 | 06:53 PM
gsrcolt's Avatar
Default Re: honda expert i need help (tpham_autotecks)
does your heater work... if not, possible blocked heater core....
Old May 27, 2008 | 08:22 PM
Default Re: honda expert i need help (gsrcolt)
heater is working when lower got warm, but when lower hose getting cold then i will have no heat.
Old May 27, 2008 | 09:05 PM
Dc2alldawaY's Avatar
rad cap?
Old May 28, 2008 | 01:23 AM
Default Re: honda expert i need help (Dc2alldawaY)
i just replaced new radiator cap just 3 days
Old May 28, 2008 | 03:13 AM
gsrcolt's Avatar
I would recommend flushing the system by taking off one of your heater hoses and puttting a water hose to it and do the same thing to the heater core. Sounds like u got a blockage or air pocket
akteamster
Jan 5, 2013 02:26 PM
B18c1vicrx
May 13, 2009 01:01 PM
martiw2
Oct 26, 2008 08:10 AM
TypeR0186
Dec 4, 2004 01:40 PM
TypeR0186
Dec 3, 2004 09:16 PM
