Please help with foglight wire harness
I bought a set of ebay fogs and the wire harness is totally different. Can anyone please help me? I don't even have a 6 pin connector. I don't mind buying a set from the dealer if I have too but this is frustrating! None of thes wires even match with whats inside my car. 07 si sedan.
Please help.:confused:
I boought a set if yellow fogs and it came with the same wire harness... I spent a lot of time trying to figure it out and realized that the wire harness is utterly the wrong one...
keep the fogs, count the wire harness as a loss and purchase an OEM wire harness...
I believe that the wire harness they send in this kit is made for a 2006 which is a different connector.
same issue... go to dealership get the oem one.. and while ur there ask them to print out the directions.. they should do it for free and well it makes it super easy
This should serve as proof for whoever purchased from k2motors and/or other companies.
I have two harnesses here:
Harness #1 (k2 motors/others look similar to this as well)
Harness #2 (OEM from Honda, Part Number: 08V31-SVA-10030)
Comparison between both relays.
Left-Aftermarket-typical 4pin relay found at autozone, etc. Right-OEM Mitsuba 4-pin relay(7001)
Differences between Aftermarket and OEM switch
Left-OEM....Right-Aftermarket
The socket is DIFFERENT on both switches. So, if you're using an OEM harness, your aftermarket switch WILL NOT FIT.
You could just use the power from the Aux connector in the inerior fuse box if the terminal fits. I had mine wired that way for two years....only problems is the lights on the dash don't work for the fog indicator.
How much are the wire harnesses from honda, and how long did it take everyone to install there fogs i got a 4dr sedan if anyone has answers for the sedans.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94jdmeg »</TD></TR><TR><TD CLASS="quote">How much are the wire harnesses from honda, and how long did it take everyone to install there fogs i got a 4dr sedan if anyone has answers for the sedans.</TD></TR></TABLE>
My apologies for the late response. If you go to hondaautomoticeparts.com and search on their catalog(it must be from a 2006 civic coupe), you will find the harness. If you choose another year or the sedan, they will give you the harness for the stalk which is wht you don't want.
You're going to need the following:
http://www.hondaautomotivepart...81%29
#4, #9 and #11.
Installation is pretty straight forward. If you want a link to the installation with the harness for the switch, let me know. I have it uploaded.
#4, #9 and #11.
