HELP! Non-Honda Question: Clutch Problem
Old Jul 15, 2002 | 08:35 PM
fredren's Avatar
Default HELP! Non-Honda Question: Clutch Problem
I just swapped the B6T engine into my festiva. I had to use a specially machined festiva flywheel, with a ACT Heavy Duty pressure plate intended for a Suzuki Swift, along with a stock swift disk that I picked up from Napa/Uap. This is a proven setup, and has been used by the few other people who have done this swap.
My problem is this: With the clutch pedal depressed to the floor, and the tranny in 1st, I cannot move the car without pushing very hard, its almost like a automatic car in park. When I do get the car moving I can hear a sound coming from the clutch, it sounds like your hand rubbing a cement wall (?couldn't think of any other example!) The freeplay is adjusted to the proper spec, so it won't be that.
Do you have any clue as to why it would be doing this?
Heres some pics of the engine in the car:
Thanks for the help!
Old Jul 15, 2002 | 09:11 PM
fredren's Avatar
Default Re: HELP! Non-Honda Question: Clutch Problem (fredren)
does anyone know?
come on guys, i'm flipping out, i need to get this car running!
Old Jul 16, 2002 | 05:36 AM
LRCivicEX's Avatar
New User
is the clutch mechanical, or hydraulic, either way sounds like you've got some adjusting/bleeding to do.
Old Jul 16, 2002 | 11:41 AM
fredren's Avatar
Default Re: HELP! Non-Honda Question: Clutch Problem (LRCivicEX)
Its a cable actuated mechanical clutch. If you look close enough in the 2nd picture I posted, you can see the clutch arm beside the turbo bypass valve, the cable isn't attached in that pic though...
I still have no idea what the problem is... adjusting it does nothing
Nickb257
Transmission & Drivetrain
Oct 30, 2011 08:45 PM
bigluelok
Dec 12, 2010 05:00 PM
00blkSi
Sep 19, 2009 04:37 PM
SHREK3D
May 17, 2005 06:12 PM
vxnine
Jun 8, 2004 11:36 AM
