Need some electrician help please
get a voltage meter and see if you have any current going to it, if not .... trace it to where ever it goes and replace it or splice it thats what i had to do on my 95 teg when i corner lights didn't work. trust me its not that hard to trace out the wire path and get it replaced with a new wire.
thanks for the replies I did try to check it with a voltage meter and that wire is just dead. Fuses are all good too, I'll try to trace the wire path although im a noob at this thanks for the tips.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc7 »</TD></TR><TR><TD CLASS="quote">thanks for the replies I did try to check it with a voltage meter and that wire is just dead. Fuses are all good too, I'll try to trace the wire path although im a noob at this thanks for the tips.</TD></TR></TABLE>
You're gonna have to back probe that wire until you find the short. Then you can replace the wire or component causing the short.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">
You're gonna have to back probe that wire until you find the short. Then you can replace the wire or component causing the short.</TD></TR></TABLE>
ahh sounds like trouble. Do i need to take off my front end to trace this wire and is this something i can do myself or better to take it to a shop? thanks
