Quaife LSD...
Old May 26, 2008 | 06:08 PM
drSquish's Avatar
Default Quaife LSD...
my new B16/LS Quaife LSD will rattle (like somethings loose) if I shift its weight from side to side.... is this normal?
Old May 26, 2008 | 08:27 PM
drSquish's Avatar
uh....
Old May 27, 2008 | 07:26 AM
American.Graffiti's Avatar
Default Re: (drSquish)
I dont believe so, did you tq everything to specs? and although Im not familiar with the quaife setup I do know they have clutch plates inside them. Did you follow the manual on how to properly set them up? I plan on doing the same setup sometime this summer.
Old May 27, 2008 | 07:49 AM
drSquish's Avatar
The quiafe is still in the box, unmounted. I thought the quaife was entirely gear operated, hence their long lifetime and reliability.
Old May 27, 2008 | 10:00 PM
drSquish's Avatar
so i take it this differential is not supposed to make noises when you shake it. I do not have the invoice from its initial purchase, can I still redeem the warranty from quaife?
Old May 28, 2008 | 12:15 PM
drSquish's Avatar
To answer my question, a virgin LSD will make some noise. My mechanic told me there has to be some play on certain parts internally. If it hasn't been dipped in tranny oil then it will make that noise.
Craigp23usa
Feb 12, 2007 05:19 PM
one^g
14
Nov 14, 2005 12:31 PM
SC-MK1
Jun 18, 2005 04:09 PM
GummyBeng
Sep 3, 2003 07:04 AM
sp0017
Aug 14, 2003 02:48 AM
