Circuit Worx drivetrain issue...
Tired of snapping axles at the track in the past, so i wanted to get my buddies Circuit Worx spool and axles, but it is for a B16a tranny and I have a GSR tranny.
How can i make that work? Do i have to take the GSR gears out and put them in a b16 tranny casing so the spool will fit correctly?
THANKS!
-wade
THANKS!
-wade
the cases are the same. its the differential on the gsr which has a larger diameter bolt pattern. both the b16 and gsr trans share the 4.4 final.
you need a b16 ring gear to fit the spool or whatever the driveline uses, and thats it.
igorka_91
Transmission & Drivetrain
16
Aug 18, 2010 01:22 PM
