wuts the differance between obd1 and obd2 gsr b18c motors
Old May 26, 2008 | 12:51 PM
250r king's Avatar
Default wuts the differance between obd1 and obd2 gsr b18c motors
im wanting to order a b18c vtec motor but dont know what one to get obd1 or obd2
Old May 26, 2008 | 02:54 PM
delsolcharli's Avatar
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (250r king)
what is it going in..then make your decesion on that
if its going in a 92-95 civic..obd1
96-00 obd2
alot of people like obd1, less sensors to worry about
you can do obd1into an obd2 car...
as far as the difference...just more sensors
im sure someone else on here can give you a more indepth answer
Old May 28, 2008 | 09:14 PM
250r king's Avatar
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (delsolcharli)
thanks the motor is goin into my 93 del slow
Old May 28, 2008 | 09:18 PM
nskforlife's Avatar
if you're buying one thats obd1 you'll have less headache.
plus it should come with a obd1 ecu, which you can chip.
Old May 29, 2008 | 10:20 PM
250r king's Avatar
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (nskforlife)
wut company should i get my motor from i was told by some friends that hmotorsonline was a good company to order from but a little $ for me i guess. im cheap but wanting the best bang for my buck im get the b18 c motor with the s80 tranny
Old May 29, 2008 | 10:48 PM
ReactioN's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 250r king &raquo;</TD></TR><TR><TD CLASS="quote">wut company should i get my motor from i was told by some friends that hmotorsonline was a good company to order from but a little $ for me i guess. im cheap but wanting the best bang for my buck im get the b18 c motor with the s80 tranny </TD></TR></TABLE>
Hmotors if you want best bang for your buck
Old May 29, 2008 | 11:23 PM
Deetz's Avatar
Crazy Honda Guy
The engines and tranny's are pretty much the same and make the same power. Really, the only difference is the ecu, and yes, obd1 would be the one of choice. Although an obdII engine is newer and probably has less clicks.
Old May 30, 2008 | 01:07 AM
raidacaipo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 250r king &raquo;</TD></TR><TR><TD CLASS="quote">thanks the motor is goin into my 93 del slow</TD></TR></TABLE>
you should get an obd1 motor with an obd1 ecu for your car.. 92-95=obd1 96-00 =obd2.. make sure whatever motor u get should be the same year as ur car or newer. in this case a gsr would be 94-97 I believe, therefore you can pass smog. and if you go with hmotors they only sell japanese engines. which means u cant pass smog without some modifications in the future. if I were you look for a usdm b18c1 motor instead of a b18c gsr.. good luck.
Old May 30, 2008 | 06:46 AM
be3zy05's Avatar
Like everyone else is saying depends on the car you are droping the motor into. I put an obd1 into my 95 coupe. Try looking into jdm unlimited for the motor. Those guys have helped me out a lot. Great deals.
Old May 31, 2008 | 12:16 AM
250r king's Avatar
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (be3zy05)
so wut would be the better company japan general motors or hmotors online
Old May 31, 2008 | 01:48 AM
raidacaipo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 250r king &raquo;</TD></TR><TR><TD CLASS="quote">so wut would be the better company japan general motors or hmotors online </TD></TR></TABLE>
your not getting the picture here.. how are u going to pass smog?? if ur gonna go gsr then at least get a usdm gsr and not a japanese one..
Old Jun 2, 2008 | 09:35 PM
250r king's Avatar
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (raidacaipo)
WELL THANKS FOR THE HELP MOTOR ON ORDER AS OF 6:OO CENTRAL TIME
Old Jun 9, 2008 | 02:34 AM
enigma's95's Avatar
so dropping an obd-2 gsr into my 95 civic wouldnt allow for more parts or anything like that? the powerband is the same on both the obd-1 and obd-2? my friend said id end up with more horsepower in the obd-2 than i would the obd-1 if i modded them the exact same way...is this true? thanks for the patience!
Old Jun 9, 2008 | 04:48 AM
Lmgrcivic's Avatar
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (enigma's95)
no its not true. the ecu is different and obd2 has more sensors. and more headaches.
Old Jun 9, 2008 | 05:17 AM
HondamanXxX's Avatar
GO GIANTS!
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (Lmgrcivic)
Sources have told me that in Japan, there is no such thing as OBD2 motors. My motor has a FITV and I got an "OBD2" JDM GSR.... They just want you to pay more.
Old Jun 9, 2008 | 06:32 AM
Deetz's Avatar
Crazy Honda Guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lmgrcivic &raquo;</TD></TR><TR><TD CLASS="quote">no its not true. the ecu is different and obd2 has more sensors. and more headaches. </TD></TR></TABLE>
The ecu is no big deal, just do a obdI conversion on the newer engine, there no downside to using the newer set up.
An obdI and OBDII gsr engine have the same amount of sensors with the exception of an extra one extra or sensor.
The exact differences are the distributor for obdI has 2 small plugs and an internal crank angle sensor, the obdII version has 1 larger plug coming out of it with the exact same wires coming out of it, color for color less one wire, which is because the crank angle sensor is located on the other side of engine right by the crank.
The injectors have the same values, but a very slightly different plug style.
Old Aug 29, 2008 | 10:29 AM
1990notch's Avatar
Default Re: wuts the differance between obd1 and obd2 gsr b18c motors (Deetz)
Does the difference in crank angle sensor location mean that the obd1 and obd2 crankshafts are different? Or are they swappable between obd1 and obd2?
Old Aug 29, 2008 | 10:43 AM
Mikej425's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raidacaipo &raquo;</TD></TR><TR><TD CLASS="quote">
your not getting the picture here.. how are u going to pass smog?? if ur gonna go gsr then at least get a usdm gsr and not a japanese one.. </TD></TR></TABLE>
haha well he lives in louisiana and idk about all of the south but here in alabama we dont have to pass smog or anything
Old Aug 29, 2008 | 11:51 AM
94EG8's Avatar
Seagull Management
OBD1 would be the way to go if you ask me. OBD2 GS-R engines are different in the following ways:
- different distributor plugs
- vtec solenoid does not have a pressure switch and the corresponding ECU wont look for it
- OBD2 engines have a CKF sensor
I'm sure there are other minor differences but thats all i could think of.
fromthesun_93
Aug 31, 2011 05:07 PM
erich73
May 2, 2007 09:10 AM
crazy4hp
Feb 3, 2007 09:14 AM
SPOONfdEK
May 27, 2003 06:32 PM
oioioi
Sep 17, 2002 12:15 PM
