12.1 cr on stock block
Old May 26, 2008 | 07:02 AM
tofu-eg's Avatar
Default 12.1 cr on stock block
I have a jdm ITR swap and before I go out and spend all the money on sleeving my block..i was just wondering how would a 12.1 cr on a stock ITR block with some sk pro 2 do?? The real question is..Will it hit the 210whp mark???
Old May 26, 2008 | 07:18 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: 12.1 cr on stock block (tofu-eg)
https://honda-tech.com/zerothread/1387968
read #4
Old May 26, 2008 | 07:26 AM
tofu-eg's Avatar
Default Re: 12.1 cr on stock block (00Red_SiR)
will i read that long before i posted but i just wanted to see what other people that have done the same setup or similar to cam out with...im pretty sure you're going to tell me to do my research too but i've did and couldn't find one..but if anyone can help that would be plus..
Old May 26, 2008 | 07:34 AM
00Red_SiR's Avatar
All Motor Mentor
reasearching doesn't always give you an exact answer but it usually gets you pointed in the right direction. Have you checked out https://honda-tech.com/zerothread?id=1263436 yet? You'll see not many people run the pro 2 cams on a 1.8L but better yet, you'll see what part combinations you'll need to use to get to your desired power level. Do searches on people like b19coupe and Tbone etc, you'll be amazed what you'll learn.
Old May 26, 2008 | 07:41 AM
tofu-eg's Avatar
thnnks man...that's all i wanted to hear...i guess imma go ahead and just sleeve my block...
Old May 26, 2008 | 08:14 AM
mar778c's Avatar
Community Builder
Community Influencer
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu-eg &raquo;</TD></TR><TR><TD CLASS="quote">thnnks man...that's all i wanted to hear...i guess imma go ahead and just sleeve my block...</TD></TR></TABLE>
Why? are you planning to go to 84-85.5 mm? Stock sleeves blocks can make 225+ with the right combination of parts. Search the dyno thread at the top of the page or see my sig with b19coupes build.
Old May 26, 2008 | 10:39 AM
IntegraType-R's Avatar
Default Re: 12.1 cr on stock block (mar778c)
i run 12.0 on a stock block
Old May 26, 2008 | 02:28 PM
tofu-eg's Avatar
yea 84mm is what i was looking for.....but alright i'll take a look at it...
Old May 26, 2008 | 02:29 PM
tofu-eg's Avatar
Default Re: 12.1 cr on stock block (IntegraType-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">i run 12.0 on a stock block </TD></TR></TABLE>
what chu got done to it??
Old May 26, 2008 | 03:30 PM
Stock c5 block
Milled head, 1 layer hg
High compression valves.
Old May 26, 2008 | 04:11 PM
wtf
i'm talking about compression dude..
Old May 26, 2008 | 04:13 PM
tofu-eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">wtf
i'm talking about compression dude..</TD></TR></TABLE>
o **** noob mistake...sorry dude
MikeyL513
Apr 17, 2012 05:57 PM
Mutiny1
Feb 5, 2010 10:57 PM
GsrIntegra789
Jan 27, 2008 02:29 PM
DelSolMike
Sep 3, 2005 02:18 PM
