Honda S2000 Honda S2000
honda s2000 engine rattle
Old May 26, 2008 | 12:36 AM
jamsan's Avatar
Default honda s2000 engine rattle
I have a 2000 S2000 covered just 49,670 miles, there is a very noisy rattle from the engine that comes in on acceleration and then goes, is this quite common? if so can someone tell me what this is and the cure, could it be tappets, timing chain, tensioner ? Jamsan
Old May 26, 2008 | 12:52 AM
dagle's Avatar
Default Re: honda s2000 engine rattle (jamsan)
a rattle? it might just be that you need a valve adjustment.. can u describe the conditions of this rattle and what it sounds like? (a tapping, a pinging, popping noise..?)
Old May 26, 2008 | 12:57 AM
HondaKyle's Avatar
The hamster that spins the V-tec wheel for your vtec is hungry. Once you feed him the sound will go away
Old May 26, 2008 | 02:29 AM
jamsan's Avatar
Default Re: honda s2000 engine rattle (HondaKyle)
Thanks for your info, if the car is ticking over and you blip the throttle the noise will come in, it sounds like little ends but Iam sure its not, tappets maybe or could it be the tensioners, deff top end
Old May 26, 2008 | 02:31 AM
jamsan's Avatar
Where is this wheel is it easy to get to and what should we feed it with?
Old May 27, 2008 | 06:07 AM
White Smoke's Avatar
i my honda
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamsan &raquo;</TD></TR><TR><TD CLASS="quote">Where is this wheel is it easy to get to and what should we feed it with?</TD></TR></TABLE>
HAHA Best noob comeback I have seen this year
Old May 27, 2008 | 06:49 AM
purehonda's Avatar
Default Re: honda s2000 engine rattle (White Smoke)
Sounds like the TCT. Open the hood and give it throttle so you can try and find where the noise is coming from.
Old May 27, 2008 | 06:51 PM
em_ekohc's Avatar
Agreed TCT, they are a common problem on ap1s
Old May 28, 2008 | 06:00 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (em_ekohc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White Smoke &raquo;</TD></TR><TR><TD CLASS="quote">
HAHA Best noob comeback I have seen this year </TD></TR></TABLE>
agreed... hahaha
Old May 28, 2008 | 12:46 PM
HondaKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jamsan &raquo;</TD></TR><TR><TD CLASS="quote">Where is this wheel is it easy to get to and what should we feed it with?</TD></TR></TABLE> They like v-power from shell
Old May 28, 2008 | 04:29 PM
Firstoost's Avatar
Does it happen when the motor is cold? Timing chain tensioners usually will be heard when the car is idling when cold. Hot too, but mine was loudest when the motor was cold.
Old May 28, 2008 | 08:04 PM
wjkj08's Avatar
Very wierd this topic popped up when it did. Mine is also doing this and my mechanic told me the valves need to be adjusted like someone said above.. Is this common and does it hurt the car?
Old May 9, 2010 | 04:06 PM
uptap1's Avatar
maybe buying a 2003 s2k and it has a tapping/rattle from the head, think its the valves. But mine only starts making noise after it has been running for 8-10 min. Not too sure what it is exactly def will have it looked at before purchasing
Old May 10, 2010 | 05:02 AM
i my honda
Global Mod
The S2000 engine is a fairly noisy one. If you are worried about it, have a professional mechanic check it out before you buy. A compression test is a must!
Old May 10, 2010 | 06:27 AM
EJAYATE's Avatar
I Deliver
Mine makes alot of noise but so did the other 10 or so i test drove. Even the brand new one that i drove was not quiet.
Old May 10, 2010 | 06:36 PM
kevinnuh's Avatar
I also experiance this kinda of engine rattle. when I rev softly it suddenly drops to 300rpm and goes up. It doesnt happen often. It often happens when its cold outside (engine warmed) or after i pumped gas in.
Old May 12, 2010 | 03:32 PM
bigmacnfries's Avatar
put a thin header on it and it gets even noisier
Old May 13, 2010 | 03:19 PM
ronnycage's Avatar
honda reccomends getting the valves adjusted every 60k on the s2000... i did mine but the most common rattle ive came into contact is the fuel rail cover rattles quite often on them... it has yet to happen to me but ive seen it 4-5 times and the kids are like "o didnt realize it was something simple like that" ck that before you drop $ on the valve adjustment. if you wanna learn to do the valves yourself and went the specs pm me.
MonKK
Honda S2000
71
Mar 19, 2013 03:16 PM
kotetu
Honda S2000
Dec 17, 2004 01:20 PM
magic15x
Honda S2000
29
Oct 31, 2004 05:46 PM
bail1911
Honda S2000
66
Feb 12, 2004 03:15 PM
WarriorSeer
Honda S2000
30
Dec 31, 2003 05:25 PM
