speedometer/gauge cluster help
Everything in my cluster works fine but my MPH wouldnt work at all. it worked last month for like an hour and it stopped again. I tried unplugging the VSS and plugging it back in but did not work. I also tried to put on a new cluster and still the same problem. What can be my problem? Any help is appreciated. oh yeah i got a 93 hb with GSR motor
you could have a faulty speed sensor.. the gear on the bottom of the sensor could be worn.. or have fallen off.. might be a wiring problem.. see if you have power to one of the 3 wires to the sensor.. check for ground at one of them as well.. you could always check for continuity between the sensor and the gauge cluster or ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gorillapno »</TD></TR><TR><TD CLASS="quote">where can i find the VSS code?</TD></TR></TABLE>
check engine light
you can find how to check the the code in the FAQ section all you need is a peice of wire
Also pull the senor out and look at the gear if you need a new gear i have one lying around lol
check engine light
Usually, if the check engine light is not showing a code, you probably have a problem with speedo unit in cluster or wiring.
I had the same problem, it was the speedo unit. I changed out the pc board and gear driven motor on back of speedo with a used unit to keep my mileage same. It's not too hard if you watch what you are doing.
Be sure to take screw out behind emergency flasher unit before taking out cluster surround.
yeah i tried to put on my brother's cluster which was working perfectly in his car but it still did not work on my car. what i found weird was there was two small harness on mine and only one on his. he has a 92 civic si hatch and i got 93 civic hatch cx.
joethejoeman
Jan 18, 2007 04:50 PM
