h22 problem
Old May 25, 2008 | 09:35 PM
hondah23eg's Avatar
Default h22 problem
i was wondering what axles for h22 would be best fit on eg. and what mount? haha please help me!
Old May 26, 2008 | 07:39 AM
h22civicsedan's Avatar
Default Re: h22 problem (hondah23eg)
mounts u have to get the ones for the swap and axles i would recommend the same hswap axles.. rated to a certian amount of hp.... if you dont u will have the same problem that i did and break axles all the time and its not worth it
Old May 26, 2008 | 08:07 AM
h22civic88's Avatar
Default Re: h22 problem (h22civicsedan)
I am running HCP Engineering mounts on my h22 swap... And for axles I highly HIGHLY recommend the hasport h22 swap axles they sell for 350 for the pair! I did the honda factory hybrid axle junk, and its works fine just easier and stronger! I've already broke fact. axles! Hasport axles ftw! lol
Old May 26, 2008 | 11:08 AM
hondah23eg's Avatar
Default Re: h22 problem (h22civic88)
thanks alot for your help guys. i was also wondering if there are any oem axles i can use? like the prelude stock axles? or is the axle too long for my eg hatch?
Old May 26, 2008 | 11:11 AM
h22civic88's Avatar
for the passanger side you use the inside cv of a prelude and you a da integra axle from the hub to that using the cv joints and all from the da the passanger side depends on what intermediate shaft you use
Old May 27, 2008 | 03:24 PM
hondah23eg's Avatar
ahah thanks alot.
Old May 27, 2008 | 06:09 PM
heres a link to everything u need to know for an h22 swap
https://honda-tech.com/zerothread?id=650329
tealchief
Transmission & Drivetrain
Jan 28, 2010 08:35 PM
HATCH22A
Jan 5, 2010 06:54 AM
djroven
Apr 12, 2007 08:44 AM
redline201
Mar 31, 2004 12:09 PM
tonesdef
Jul 11, 2003 12:37 AM
