B16 starting problem
Old May 25, 2008 | 12:52 PM
Upper Hand's Avatar
Default B16 starting problem
Hey Im new here I have few problems..any help appreciated
I just bought a 1997 EK4 Si with a B16 (JDM car),the engine was out the car when I got it as it was being rebuilt.
I just put the engine and gearbox in,and now with everything hooked up it wont start.Cranks over ok but no fire.I have spark and fuel and I just reset the timing to make sure but still no luck.
Also my dizzy is moving up and down and so is the plate over the intake cam at the cam gear end everytime the lobe for #1cylinder touches the lifter..
Im thinking I need another camshaft??
HELP PLEASE!!!
Old May 25, 2008 | 01:23 PM
jdmphilep's Avatar
Default Re: B16 starting problem (Upper Hand)
TRY CHECKIN THE CAMSHAFT SPROCKETS AGAIN...ARE THEY FACING THE SAME DIRECTION, THEY "UP" SHOULD BE FACING UP AND THE TWO TIMING MARKS SHOULD BE ALIGNED WITH THE POINTER ON DA REAR COVER . WHEN IN THE CRANKSHAFT PULLEY...THE WHITE MARK SHOULD BE ALIGNED WITH THE POINTER(IN THE TIMING BELT COVER)
Modified by jdmphilep at 2:42 PM 5/25/2008
Old May 25, 2008 | 06:25 PM
Upper Hand's Avatar
Default Re: B16 starting problem (jdmphilep)
cam gears been rechecked three times now..theyre set right.
Im going to pull the cams tomorrow and see so anymore ideas please,I really need this car running asap..
Old May 25, 2008 | 07:09 PM
ek4_b16a's Avatar
check your grounds
Old May 25, 2008 | 07:20 PM
Gunni's Avatar
"dissy is moving up and down"
The pins on the distr. don't line up so it could be 180° wrong into the cam.
DohctorVtec
25
May 1, 2006 02:12 PM
hondastreets1
Dec 31, 2005 02:24 PM
honDA16
Dec 6, 2004 06:03 PM
