Crank Bolt Pulley Tool
Old May 25, 2008 | 02:26 AM
DDEVIANT1's Avatar
Default Crank Bolt Pulley Tool
I am about to do the headgasket and everything associated belts water pump seals.... on my gf's 97 accord DX, and was just curious if I will need the crank bolt tool or not. Just want to make sure because I am gonna order from TAS and don't want to forget anything. And on that note how is TAS to deal with??
Old May 25, 2008 | 09:52 AM
blkb18's Avatar
Default Re: Crank Bolt Pulley Tool (DDEVIANT1)
If you have a powerfull enough 1/2 inch impact and/or good torches you will be fine. If not then get the tool.
Old May 25, 2008 | 04:22 PM
1992Si's Avatar
I would try and break that crankshaft bolt loose the weekend before you plan to do the job.
If you can't get it loose you have the week to find someone to do it for you.
This is a big job, do you know how to do everything?
Old May 25, 2008 | 07:41 PM
DDEVIANT1's Avatar
Default Re: (1992Si)
I did the timing belt, water pump, and what not on my d15b7 with no problems... is there more I really have to worry about, I am gonna get the head pressure checked and milled as necesary, other than that??? if anyone has any suggestions or tips let me know.
new_climber
Honda Civic (2001 - 2005)
Sep 3, 2017 07:07 AM
1sgranger75
Nov 14, 2014 08:13 AM
Cpt.trips
Aug 3, 2014 01:59 PM
93gsrcoupe
Sep 30, 2004 09:54 PM
Tad
12
Feb 9, 2004 05:13 PM
