Shift boot looks stupid
Old May 24, 2008 | 08:51 PM
Toe_Knee's Avatar
Default Shift boot looks stupid
I just put on a Skunk2 shift ****. Now it looks like my shift boot is like halfway down the shifter. There's too much space between the bottom of the **** and the plastic ring on the boot. The plastic ring is also cracked. The boot isn't propperly attatched to the plastic square on the center console either, it's weird. Any help?
Old May 24, 2008 | 09:29 PM
BlueIntegraBoy's Avatar
Default Re: Shift boot looks stupid (Toe_Knee)
A trick to make the boot stay up is to use a zip tie and put the zip tie on the shifter itself. Not too sure what you mean by it's not properly attached to the shifter console.
Old May 25, 2008 | 05:16 AM
SleeperGSR's Avatar
Default Re: Shift boot looks stupid (BlueIntegraBoy)
i pushed mine all the way down and i think it looks pretty good.
Old May 25, 2008 | 02:40 PM
lickety_britches's Avatar
its not going to. the integra shift **** is way deeper. i have the exact same problem. just live with it. its no big deal. unless your freakin out about it
Old Jun 25, 2008 | 01:48 PM
Honduh Chicken's Avatar
I fry gay turkeys
Default Re: (lickety_britches)
short shifter? It would bring the boot closer to the ****.
Old Jun 25, 2008 | 02:42 PM
B18IntegraLS's Avatar
Reject Pimp
Theres a couple options.
-Buy a new boot
-Use a zip tie (thats ghettofied)
-Short Shifter (will bring boot up.)
Old Jun 25, 2008 | 04:20 PM
Spody02's Avatar
Default Re: Shift boot looks stupid (B18IntegraLS)
or take the boot off..
put a nut at the bottum where of the shift **** goes
put the boot back on
THERE YOU GO!
Old Jun 25, 2008 | 06:38 PM
dispocrx's Avatar
ok guys i saw this a loooooooooooong time ago, or i thought about it....one of the two, take a good o'l 20oz coke bottle cap, cut a + right in the middle of it, place it under your shiftboot at desired height. Done easy free fix...assuming u can find a coke cap layin around somewhere.
Old Jun 26, 2008 | 09:22 AM
I fry gay turkeys
Default Re: (dispocrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dispocrx &raquo;</TD></TR><TR><TD CLASS="quote">ok guys i saw this a loooooooooooong time ago, or i thought about it....one of the two, take a good o'l 20oz coke bottle cap, cut a + right in the middle of it, place it under your shiftboot at desired height. Done easy free fix...assuming u can find a coke cap layin around somewhere.</TD></TR></TABLE>
A coke cap is hard plastic, it would slide down. Bad idea.
Better off using a tight fitting o-ring, or a rubber grommet, and a little super glue to to make a "stop" ring at the desired height.
Old Jun 26, 2008 | 09:24 AM
I fry gay turkeys
Default Re: (Honduh Chicken)
Not the best idea, but I've also seen people use round and round and round with electrical tape until it builds up far enough to stop the boot from slipping over it, but after time I've found that it heats up and makes a sticky mess around the top of the shift boot.
Old Jun 26, 2008 | 09:29 AM
super jdm yo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honduh Chicken &raquo;</TD></TR><TR><TD CLASS="quote">Not the best idea, but I've also seen people use round and round and round with electrical tape until it builds up far enough to stop the boot from slipping over it, but after time I've found that it heats up and makes a sticky mess around the top of the shift boot. </TD></TR></TABLE>
i've seen that too. if you're really that worried about your boot just get another one, that plastic ring that you say is broken is what's going to keep the boot from sliding down.
Old Jun 26, 2008 | 11:13 AM
denraweb's Avatar
Default Re: Shift boot looks stupid (SleeperGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">i pushed mine all the way down and i think it looks pretty good.</TD></TR></TABLE>
x2
Old Jun 26, 2008 | 11:45 AM
TOO MUCH TORQUE's Avatar
i think it looks cool with it half way.
Old Jun 26, 2008 | 02:16 PM
bakertime's Avatar
Default Re: (TOO MUCH TORQUE)
^ X2
I went to Ace Hardware and picked up a black snap grommet, either 1/2 or 5/8's, can't remember, just buy one of each... I put some black electrical tape around it until it fit snugly into the stock ring. Then shove it in and slide it down as far as it goes. That way it is snug (provided you use enough tape to snug it up) and actually looks like it's supposed to be there. It looks like the picture above, but closeup it still looks clean, with no big gap in between the ring and the shifter lever itself.
Hope that helps!
Old Jun 26, 2008 | 02:25 PM
JReal's Avatar
short shifter
galognu
Transmission & Drivetrain
Feb 2, 2016 05:39 PM
Cap'N Chronic
Dec 26, 2011 09:57 AM
PatrickGSR94
Apr 4, 2010 09:03 AM
JDMtweezy
Honda S2000
May 6, 2007 11:57 AM
-KangaRod-
May 15, 2004 07:12 AM
