first time engine removal
Old May 24, 2008 | 02:16 PM
93preludeh22's Avatar
Default first time engine removal
I'm removing the stock motor from my CX and I'm following along in the Honda service manual for removing the engine. I'm ready to pull the motor and I just wanted to make sure that I was doing something correctly... The manual states
"Remove the A/C belt and compressor
*Do not disconnect the A/C hoses.
*Disconnect the connector."
I've removed the A/C belt <check>
I've removed the four bolts holding the compressor <check>
Now my A/C compressor is kinda just hanging there in the engine bay...seems like this might be an issue when pulling out the motor... Is this correct?
Old May 24, 2008 | 02:25 PM
Urban Racer's Avatar
Default Re: first time engine removal (93preludeh22)
Strap it on the side and have someone checking that it clears when pulling the engine out.
Old May 24, 2008 | 02:26 PM
OK, thanks for the help!
Gavin Ward
13
Dec 16, 2014 06:05 AM
crzy1208
Jan 23, 2013 03:03 PM
wfocrx
Mar 8, 2007 06:29 PM
Lost_clearance
May 29, 2006 06:41 PM
kyosuke714
Dec 12, 2005 05:29 AM
