quick question
Old May 24, 2008 | 09:54 AM
97civhatchy's Avatar
Default quick question about motor mounts
i kno to some guys on here it's a no brainer so so not really lookin for any smart ace comments. but would i need to change the motor mounts in my 97 civic hatch to put a stock ls in or could i just use the da's mounts?
Modified by 97civhatchy at 10:31 AM 5/25/2008
Old May 25, 2008 | 08:53 PM
vtecb18c's Avatar
Default Re: quick question about motor mounts (97civhatchy)
drops right in
Old May 26, 2008 | 07:10 AM
Default Re: quick question about motor mounts (vtecb18c)
SWEET bro thanks alot
Old May 29, 2008 | 11:15 AM
vtecb18c's Avatar
bump
Old May 29, 2008 | 08:21 PM
inspyral's Avatar
You'll need the rear tranny bracket from a 99-00 Si. You can reuse the rest of your stock mounts, but you may need to change out the half of the mount that bolts to the block on the driver side(the one with the 2 thread posts in it).
The rear tranny bracket looks like this:
You can get it here:
http://passwordjdm.com/OEM-EK-....aspx
or at any Honda dealer.
Old May 30, 2008 | 06:38 PM
rdeezy78's Avatar
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">You'll need the rear tranny bracket from a 99-00 Si. You can reuse the rest of your stock mounts, but you may need to change out the half of the mount that bolts to the block on the driver side(the one with the 2 thread posts in it).
or at any Honda dealer.</TD></TR></TABLE>
x2 I know from the fresh build I just did. You will def need this mount. Don't get an ebay knock off though. Get one from a honda dealer, you won't spend that much. Well now that I think about it, it depends on your area. GL
Old May 30, 2008 | 09:26 PM
thanks to all the replies i got a lil more knowledge now!
EKlp
May 6, 2007 01:08 PM
SPD DMN
Sep 20, 2006 01:50 PM
Grams0wnsyouz99*
Nov 8, 2005 11:10 AM
slowazz97civic
Jul 20, 2005 04:41 PM
jpcivic
Dec 29, 2003 05:52 AM
