speedometer help.. stays stuck
Old May 23, 2008 | 07:57 PM
bpowa's Avatar
Default speedometer help.. stays stuck
my speedometer stays stuck at 20mpg.. and it workes at times and some times does not.. just stays stuck.. the rpm works fine..
1996 civic ex coupe.. is it the cluster itself or speedo gear?
thanks
Old May 23, 2008 | 08:43 PM
1996Civic_CX's Avatar
Default Re: speedometer help.. stays stuck (bpowa)
There is a TSB on 96-00 civic, the wiring harness rubs against the Intake manifold bracket which is on the back of the block and shorts out the speed sensor wire causing the needle to jump around on the gauge cluster. Just take the bracket off and toss it away,wrap up the exposed wire and your good to go.
Old May 23, 2008 | 10:27 PM
bpowa's Avatar
I hope your right.. I will try.. thanks..
if anyone else has this problem dont hesitate to give input
Old May 24, 2008 | 09:59 PM
bpowa's Avatar
Default Re: (bpowa)
i checked behind the engine.. the harness has a hard plastic protective cover and the manifold bracket is behind it.. it does not rub..
any other help please..
Liamtelfer
Apr 24, 2017 07:47 AM
Aylem1
Feb 29, 2012 07:01 AM
Nobody123
Oct 23, 2011 12:40 PM
hondaB
10
May 10, 2011 11:10 AM
honda addictions
Sep 10, 2009 03:46 PM
