spongy breaks!!help
Old May 23, 2008 | 07:31 PM
Cras-Delsol's Avatar
Default spongy breaks!!help
i have a 97 del sol si with break callipers all around...my brakes sink and i have to pump it once sometimes twice....i noticed it mainly happens when i make u turns and when im am parking...i have bled the breaks and replaced my booster....i checked for leaks but there is no signs of fluid..what can i do?...they told me it might be my master cylinder?...how can i check if my master cylinder is working and maybe i just need to bleed it or something?....
thanx in advance for the help...
Old May 23, 2008 | 07:33 PM
pimpvw's Avatar
Default Re: spongy breaks!!help (Cras-Delsol)
sounds like its your mc
Old May 23, 2008 | 07:37 PM
jimmy o.'s Avatar
best replace the worn out master cylinder before you end up loosing youre brakes completely
Default Re: spongy breaks!!help (pimpvw)
is there a way to check if my mc is working?
Old May 23, 2008 | 07:41 PM
i was wondering if there is such thing as a sequence in which the brakes should be bled??...
Old May 23, 2008 | 07:48 PM
93b20z's Avatar
might be air in the system.. try bleeding it first...
RR, LR, RF, LF.. ALWAYS THE FARTHEST FROM THE MC.. then if same thing happens mc is recommended
Old May 23, 2008 | 07:53 PM
Default Re: spongy breaks!!help (93b20z)
alrigth thanx for the help..... .....
does anyone know how to bench bleed???
Old May 23, 2008 | 07:55 PM
racerxh00's Avatar
you ownt need to bench bleed, just the brake pedal and wrench method. look for a cracked brake line as well
Old May 23, 2008 | 07:57 PM
Default Re: spongy breaks!!help (racerxh00)
oh ok ...i was asking because i was told to try bench bleeding my mc
Crazed-Sol
Suspension & Brakes
Sep 1, 2009 05:39 PM
lilo_goki
Apr 18, 2008 07:59 PM
archfield1
Apr 6, 2006 03:14 PM
Wild_Chid
Sep 27, 2005 04:03 PM
ekdriver707
Sep 21, 2005 09:22 PM
