CEL code 8 quick blinks. I already searched, can't find it.
Old May 23, 2008 | 04:33 PM
rdeezy78's Avatar
Default CEL code 8 quick blinks. I already searched, can't find it.
I have a 96 ex with an obd-1 ecu and everything. I checked for the code and my cel is blinking 8 quick or regular blinks. I don't know if there is a different speed or anything. Any help is greatly appreciated. Like I said I already searched and got 247 threads.
Old May 23, 2008 | 04:37 PM
rdeezy78's Avatar
Default Re: CEL code 8 quick blinks. I already searched, can't find it. (rdeezy78)
More helpful info is that it is a boosted motor with a distributor king dizzy w/ external coil and a msd box. The cel first came on when I was listening to my radio pretty loud. Amps and all with a cap and all. I'm thinking low voltage somewhere. Except that when my radio is not on I got the cel again. So you can see where I'm getting lost, besides the fact taht I don't know the codes anyway.
Old May 23, 2008 | 05:14 PM
J. Mills's Avatar
TDC sensor. 90 percent of the time the sensor itself is bad inside the distributor.
Old May 23, 2008 | 05:16 PM
rdeezy78's Avatar
Default Re: CEL code 8 quick blinks. I already searched, can't find it. (J. Mills)
cool. I tought the distributor to starting to go. I was having some high rpm sputtering problems. So I just started to baby it, but now I guess it's getting really bad. Thanks for the help.
Old May 23, 2008 | 05:20 PM
GhostAccord's Avatar
^^x2 DTCode 8 is for the Top Dead Center sensor in the Dizzy. Check to make sure that none of your wiring came loose. Check all the connections at the distributor.
Old May 23, 2008 | 06:37 PM
rdeezy78's Avatar
Default Re: CEL code 8 quick blinks. I already searched, can't find it. (GhostAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GhostAccord &raquo;</TD></TR><TR><TD CLASS="quote">^^x2 DTCode 8 is for the Top Dead Center sensor in the Dizzy. Check to make sure that none of your wiring came loose. Check all the connections at the distributor.</TD></TR></TABLE>
I'll do that. Thanks
409-Ef8
Jan 22, 2007 03:24 PM
LilCivic04
Oct 14, 2005 09:19 AM
athoughts
12
Jul 3, 2005 10:16 AM
SweetChin
Jan 8, 2003 04:38 PM
