Exhaust decided to go. Want opinions on choices
Old May 23, 2008 | 03:04 PM
amej8's Avatar
Default Exhaust decided to go. Want opinions on choices
So as the title states, my exhaust **** the bed. Loud as [freak] and I accelerate as slow as a turtle.
I went under there to try to change my cat (because I'm 99% that was the problem) and it turns out, the bolts are so rusted on the back end connecting to the mid pipe, I can't even remove the cat alone. Not only that, but my muffler is starting to rust out bad and a hole will eventually start (will definitely be there this winter after all the salt and stuff).
So what do you guys think I should do?
A - try to junkyard an OEM used exhaust. (I have an OEM cat from my buddy, he gave it to me when he got a new cat, exhaust, and header)
B - go all out and buy a new WS2, Megan Racing header, and Magnaflow Hi-Flow cat (or use the OEM one), put it all on my credit card and pay it all off within a month to 2 months
C - other. please specify if you chose this.
Keep in mind my car is 100% stock and the engine / tranny are starting to go. Engine is coming up on 192k and needs another timing belt / water pump / head gasket / oil pan gasket (which I could change while I change out the header) / valve adjustment / etc. etc. etc.
Old May 23, 2008 | 03:13 PM
rSol93's Avatar
Default Re: Exhaust decided to go. Want opinions on choices (amej8)
just go back to stock, its not like your driving a heavily modded car, but if you want an aftermarket one try looking at a tanabe touring exhaust, i personally like the exhaust that arn't too loud, but when you step on it, its screams a little.
Old May 23, 2008 | 03:15 PM
amej8's Avatar
Default Re: Exhaust decided to go. Want opinions on choices (rSol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rSol93 &raquo;</TD></TR><TR><TD CLASS="quote">just go back to stock, its not like your driving a heavily modded car, but if you want an aftermarket one try looking at a tanabe touring exhaust, i personally like the exhaust that arn't too loud, but when you step on it, its screams a little.</TD></TR></TABLE>
True. But then again, I wouldn't mind the ever so slight increase in mpg and having the first serious modifications since I got the car 4 years ago :D.
Old May 23, 2008 | 03:26 PM
rSol93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by amej8 &raquo;</TD></TR><TR><TD CLASS="quote">
True. But then again, I wouldn't mind the ever so slight increase in mpg and having the first serious modifications since I got the car 4 years ago :D. </TD></TR></TABLE>
idk what car you drive but if it is sohc and your engine is about to go out and you buy a $500+ exhaust, and your engine gives, unless you swap in another sohc, i doubt the same exhaust/header set-up will fit a b series/dohc setup..
Old May 23, 2008 | 03:31 PM
amej8's Avatar
My car is just a stock EX. A few months ago, I planned on swapping in a B18B or B20 by the end of summer. Because I knew **** on my car (more importantly the engine / tranny) were gonna start to go soon.
But at the rate that ***** falling apart on my car, I'll probably just swap in another Y8 just for sake of money. It's just a DD. Though I would prefer a motor with a bit more torque and power, it's not a necessity.
Old May 23, 2008 | 03:40 PM
rSol93's Avatar
Default Re: (amej8)
As long as your swapping in a sohc if your engine gives, then i don't see a problem with getting an aftermarket exhaust. Heres some stuff to look at if you want.
http://hopupracing.com/exhaustheaders8.html
Old May 23, 2008 | 03:49 PM
amej8's Avatar
Yeah. The way I figure, if I'm going to be swapping in a newER / better condition engine anyways, why not spend the extra money on stuff that'll last like 10+ years with the swapped engine so I don't have to change it again you know?
Anyone else?
Old May 23, 2008 | 06:56 PM
jimmy o.'s Avatar
I just put a skunk2 catback on my DX its pretty loud but it dosent sound like crap like all the other people around here with fart can exhaust. I think i spent 390 alltogheter off ebay
tCtCtC
36
Mar 25, 2011 11:04 AM
liftandcut
Dec 27, 2005 08:04 AM
-[95cxhatch]-
Nov 6, 2003 05:47 AM
Nextelbuddy
14
May 16, 2003 09:31 AM
HatchBox
15
Jul 21, 2002 05:37 PM
