what to do first break in or tune
Old May 23, 2008 | 01:01 PM
hiphop23j's Avatar
Default what to do first break in or tune
i read you gotta break in your car b4 you get it tune and i also read you gota tune your car b4 you break it in witch one is it, i just got my gsr rebuilt and i wanted to know b4 i messed anything up.
Old May 23, 2008 | 01:11 PM
King V's Avatar
Default Re: what to do first break in or tune (hiphop23j)
If its not set up with a proper tune first, you will break it while breaking it in.
Old May 23, 2008 | 04:59 PM
rdeezy78's Avatar
If you still have the stock setup and a stock ecu then your fine. If you got a larger bore and deeper stroke like or anything then if you should get it towed to your tuner shop. The motor will start the "break in" as it gets tuned.
Old May 23, 2008 | 05:08 PM
1992Si's Avatar
Yes, if you have a know good ecu tuned for your basic set up, you should be ok.
Just keep it out of boost until it's on the dyno.
Or you can take it to the tuner and have them break it in on the dyno.
Where is nanuet NY ? There's a good tuner just west of Albany.
GoSickemRobert
Engine Management and Tuning
Mar 21, 2011 09:02 AM
twistedintegra707
Oct 15, 2006 10:40 AM
Traction
Sep 12, 2004 09:55 PM
xXx Justin xXx
May 13, 2003 12:07 PM
