NEEED HELP!!!!!
Got a 1990 Da with a 98 ls swap and my engine runs fine but the rpm gauge in the cluster don't effin work like at idle it says its at like 300 but its not i need some help and a diagram if possible???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmoney45 »</TD></TR><TR><TD CLASS="quote">Got a 1990 Da with a 98 ls swap and my engine runs fine but the rpm gauge in the cluster don't effin work like at idle it says its at like 300 but its not i need some help and a diagram if possible??? </TD></TR></TABLE>
You can either reset your ECU or take a screwdriver and go to the throttle body there is a screw turn it to the right to increase your idle higher.
