NEEED HELP!!!!!
Old May 23, 2008 | 12:41 PM
jmoney45's Avatar
Default NEEED HELP!!!!!
Got a 1990 Da with a 98 ls swap and my engine runs fine but the rpm gauge in the cluster don't effin work like at idle it says its at like 300 but its not i need some help and a diagram if possible???
Old May 23, 2008 | 01:21 PM
hatchling37's Avatar
Default Re: NEEED HELP!!!!! (jmoney45)
If it's only off at idle, why do you care? Keep in mind, the factory tach is not going to be 100% accurate
Old May 24, 2008 | 07:40 AM
inspiration's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmoney45 &raquo;</TD></TR><TR><TD CLASS="quote">Got a 1990 Da with a 98 ls swap and my engine runs fine but the rpm gauge in the cluster don't effin work like at idle it says its at like 300 but its not i need some help and a diagram if possible??? </TD></TR></TABLE>
You can either reset your ECU or take a screwdriver and go to the throttle body there is a screw turn it to the right to increase your idle higher.
jmarquar
Aug 26, 2013 11:17 AM
redED9Si
Aug 21, 2005 06:58 PM
RedEK
Dec 1, 2004 06:55 PM
EFStali
10
Aug 19, 2003 09:14 PM
