Bolt for attaching the chain when pulling a D or B series engine
Old May 22, 2008 | 04:53 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Bolt for attaching the chain when pulling a D or B series engine
Is there a bolt on my car somewhere that will fit that 10x1.25 threaded hole up near the rear left of the engine, right above the alternator? It's the hole most people stick a bolt in with a chain on it when they hoist the engine out of the bay.
Just wondering if I should go buy a high-strength bolt to fit in there or if something on my car will already fit in there. And yes I will be putting a large, hopefully thick fender washer between the chain and the head of the bolt.
It's a stock B18C1 engine, duhh
<-- Pulling the engine out Saturday morning, hope to have it running again by Monday evening, or possibly even sometime Sunday.
Old May 22, 2008 | 05:46 PM
non-VTEC's Avatar
Default Re: Bolt for attaching the chain when pulling a D or B series engine (PatrickGSR94)
what a coincedence....im pulling my engine out this weekend also.....for the 4'th time (long story)
anyway i usually pull one of the M10x1.25mm bolts from the a/c compressor bracket at the front of the block and put it in the spot you are talking about. yes use a washer also.
good luck
Old May 22, 2008 | 06:06 PM
00b18b's Avatar
yes def get a grade 8 or higher bolt for that location. I got one just for that reason. also get a nut and two washers so you can keep the chain away from the valve cover.
Old May 23, 2008 | 05:49 PM
Community Builder
hmm well I got this metric bolt from Lowe's, not sure what grade it is, though. I may just use the A/C compressor bolt or something.
Also the chains on my engine hoist have thick, flat bars at the end of each chain w/ holes in them (bar is permanently attached to the last chain link, which is welded), so I won't have any problems with the chains rubbing the valve cover.
Old May 25, 2008 | 03:57 AM
non-VTEC's Avatar
Default Re: (PatrickGSR94)
i dont know about you but just about every muscle in my body is soar right now from this engine swap. im hoping to have it running by the end of the day today...haha
Old May 25, 2008 | 08:59 AM
Community Builder
Default Re: (non-VTEC)
haha dang all I got done yesterday was getting the engine out, tranny off, and the engine up onto the stand. Now today I'll be putting the new parts on and probably won't get it back into the car till tomorrow. I also have to change the front brakes, the brake MC piston seal, and the pass. side CV axle.
And yeah I'm hurting too.
Old May 25, 2008 | 03:39 PM
non-VTEC's Avatar
woah..........you have lots of work to do still.....haha....i bet you will be another 3 days of working on that thing.
i managed to complete my task today. 8am-8pm yesterday and 8am-7pm today non-stop with only a couple 20-30min lunch breaks.......im so soar and tired but the engine never sounded/ran so good.....hehe
good luck man!
Old May 25, 2008 | 04:13 PM
1992Si's Avatar
Feels good when you do it yourself.
Congrate's.
Spent 3 hours under the dully with my 21y/o son today removing the exhaust and installing a cat delete pipe, I'm 53 y/o. Let me tell you about sore...
Old May 27, 2008 | 05:24 PM
Community Builder
Well I got the engine back in on Monday and got it running late, after 11 p.m. Runs really well and feels great with the new clutch and fresh GM Synchromesh Friction Modified.
But now I have a big problem of coolant leaking under the dashboard, I think it's because I didn't get the hose clamps on the heater hoses at the firewall back on all the way.
wevtech
Feb 8, 2011 07:05 PM
crxpwr1
Sep 23, 2006 09:30 PM
k-series
Sep 19, 2005 03:53 AM
serious
Mar 12, 2003 03:27 PM
Kamin
Jan 2, 2002 02:01 PM
